![]() | Home > Technical (L322) > It was front nearside driveshaft |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I had been chasing a whine and vibration for a while - replaced all wheel bearings front carriers rear diff and stilll it persisted now at last we have it sorted it was a worn nearside front driveshaft - there was a lot if movement in it so one to watch for suppose |
I hope it solves the problem it took me a while to find mine and I do 20 odd k a year |
Change the oil in the rear diff and if it is black and thick you may need to replace the diff - when they were manufactured they were painted on the inside and this paint peels and makes a paste which basically grinds the diff away - worth changing the oil anyway |
No it wasn't so this week have replaced the front diff and this time it is silent and no vibration - result |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Sandyt good news for you. However after having the front diff and n/s driveshaft changed the noise/rumble is still there on mine.. Hmmm. |
Well in total I changed front and rear diffs (rear had a bearing gone ) all wheel bearings and all drive shafts. I did the rears all in one go due to damage from the failed bearing,. Interestingly on the front it was the bearing in the extension arm of the diff that had failed/was failing the diff was ok maybe a little bit of wear but nothing much.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
Sorry to resurrect an old thread here…
Morning David I used genuine I always do if I can -I had trouble with an aftermarket wheel bearing years ago so just stick to genuine
Thanks Sandy, appreciate the heads up.
No I had my local mechanic do it was chatting in the pub with him and he had just done his own (he has a 2007 Diesel 3.6) so was asking if it was difficult he said no and did the lot on the front end for 150 quid so it seemed like a good idea
To be honest David he does loads of \Fatties in the village knows them well and is cheap as chips I am doing less and less even on the p38
