Home > Technical (L322) > DTCs P138E & P132B
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
DTCs P138E & P132B
During past couple of days I have been getting ENGINE SYSTEM FAULT message on start up. No change in performance. Battery reading 12.2v.
Checked codes today and got:
P138E - turbocharger boost control position sensor A - minimum/maximum stop performance
P132B - turbo/supercharger boost control A performance
Cleared codes with iCarsoft reader, restarted engine and reader confirmed no DTCs found, I have had no more ENGINE SYSTEM FAULT messages so far.
I also checked :
- Boost pressure actuator banks 1 and 2 and got readings of around 0.82% going down to around 0.70% with light revving.
- Commanded boost actuator control banks 1 and 2 with readings of around 82% going down to around 70% with light revving.
Can anybody confirm what the issue is?
Thanks in advance…..
Post #613720 24th Nov 2021 9:49pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I'd be checking the turbo actuators to make sure they're free.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #613736 24th Nov 2021 11:55pm
kgeddes
Thanks Dunc.
Do the Boost pressure and Commanded boost readings not confirm that the actuators are moving?
Post #613757 25th Nov 2021 10:31am
RRDunc
They do but they may not be moving freely.
I'd also, as a matter of course, check the hoses and associated trunking.
Post #613982 27th Nov 2021 9:11pm
kgeddes
Thanks again Dunc Thumbs Up
Post #614409 1st Dec 2021 6:52pm
