![]() | Home > Technical (L322) > Pre Heater |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
Used the pre heater for the first time this morning. How long does it take to heat up? I only put it on about 15 mins before I got in and I could hear the fans going but the car didn't seem to have warmed up. 2011 Vogue SE TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7992 ![]() ![]() ![]() |
It will only run for about 20 minutes. It doesn’t get that hot though, just enough to take the edge off. There are loads of threads on it. Folk talking about if where you have the temp dials makes a difference etc. Don’t think they affect it, as the FBH is it’s own system.
I think the run time is reduced on the later models.
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 184 ![]() ![]() ![]() |
My owners handbook for the 3.6 2010 states 20 minutes for the FBH to run, I think the petrols may be 30 minutes plus the older diesels. Definitely 20 minutes for the diesel from 2010. |
To be fair, that’s what I thought. Can’t remember where I saw it.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’ve only recently started using the FBH, and haven’t got to the bottom of these types of questions.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
After having tried mine a few times and not thinking it was working, we had a very hard frost the other day, so I decided to give it a go and low and behold, it worked a treat. Defrosted the windscreen and side windrows a treat. Got - 2017 SDV8 Autobiography in Loire Blue
I don’t think it’s supposed to do any more than that really.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Haven’t used it on the 405 much but the one on the 2012 did warm the cabin a bit, not much though unless it ran for the full time, the one on the D4 runs until the car is started and I’ve had it on for over 1/2 hour on cold mornings. it never does much other than defrost the windows and make the car not freezing. There is nothing that can't be fixed with a hammer😜😜
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I started looking into retrofitting this to my SC last year and never did. Now it’s cold I’m looking into it again. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
As mjd says...
