![]() | Home > Maintenance & Mods (L322) > Suspension not level at front |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
Just check that the arm between the sensor and the lower arm hasn't been bent when you carried out the work on it and that it's connected properly.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
The system has a +/- 10mm tolerance on each wheel before it will adjust so it may just be on the limit. 2012 TDV8 Vogue (L322) |
Leigh4571 Member Since: 09 Oct 2021 Location: Shropshire Posts: 19 ![]() ![]() |
Thanks forgot to say, I’ve checked the sensor after reading a similar issue but due to an incorrectly fitted sensor. But looks fine.
I think it's time to think about buying that IID tool |
