Home > General > just had reduced engine performance msg come up!! ??
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
On the motorway driving back from IKEA and I noticed that the car was just not pulling away. I was doing just over the legal limit honest. No error msg's came up put pulled over to hold shoulder anyway. Put my foot down but nothing happened just coasted along. Switch off engine then on again and reduced engine performance came up. Tried to pull away and nothing again. Switch engine off and on again and this time he had lift off. Car drove fine again pulled of motorway to be on the safe side and drove home. Just when I hit traffic again about 5 mins from home the warning msg came back on. Just coasted home so not tried since. I know it could be many things but is there anything I can check? No other error msg's have come up.
Thanks Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #61285 22nd Apr 2011 5:31pm
guess it might be a split hose ... ... - .- -.
Post #61287 22nd Apr 2011 6:56pm
Ludzy
Is that a fairly swrious/costly thing? I can remember when a hose when one of the hoses went in my s type JAG. Cost over £400 for a £3 hose.
Post #61288 22nd Apr 2011 7:02pm
i seem to remember the hose at the back of the engine splits and causes intermittent performance...dont know how much it costs sorry.
if the ECU has detected a fault in the system you'll need to find out why its getting that code by connecting it up to a fault reader... ... - .- -.
Post #61289 22nd Apr 2011 7:10pm
Ludzy
Think I better book it in then.
Looks like I better find a decent indy in Leicester.
Post #61290 22nd Apr 2011 7:37pm
Ludzy
Just had a look under the bonnet. Blimey the engines big ain't it! Shocked
Can deffinatley hear a faint whistle sound that only started today. Also might sound stupid but is there ment to be that much hot air blowing from the the bay near the air filter? Just took it for a little spin and all seemed fine buti didn't push it so engine wasn't put under any strain. The wifes gotta use it for work over the weekend and she never goes over 30 so I doubt if that will do any damage to it. Hopefully get it booked it on the Tuesday.
Cheers Ex FFRR 4.2 Supercharged
Post #61296 22nd Apr 2011 9:00pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Mine lost a supercharger coolant hose but that I'm writing this on my iPhone and so can't 'mouse over' your avatar. Is yours an SC? If so, mine was covered under warranty but main stealer said it would have been £200.
If not, how squishy are your PCV hoses? Dan's posted some (as usual) excellent info on PCV.
Whatever, I hope it's cheap for you!
Post #61301 22nd Apr 2011 9:39pm
Ludzy
Yes I have a SC. Just looked at Dans post about PCV very interesting read. I'm gonna have a check of mine once the wifes back. If so looks like I may get my hands dirty Shocked Ex FFRR 4.2 Supercharged
Post #61316 23rd Apr 2011 9:59am
Ludzy
Well just checked all hoses I could get to and all seem fine. Car idles abit rough but maybe I'm just being picky as it's not very noticeable. I'll have to book it in as soon as. Wanted to get it serviced aswell so I'll get that done at the same time.
Something always seems to happen to my cars when driving to ikea. This is the third time a car of mine has shown faults arfter driving there. Think somebody's trying to tell me something!
Post #61328 23rd Apr 2011 3:34pm
Stephen.125
Found this Ludzy,
http://www.rangerovers.net/forum/viewtopic.php?f=2&t=43098
Post #61373 24th Apr 2011 10:56am
Ludzy
Yeah I noticed this thread aswell. Thinks that's abit to technical for me tho. My VIN is is that range tho so could possibly be gthe cause.
Post #61374 24th Apr 2011 11:03am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
My gues is the MAF, mine throwes this fault, particularly when trundling along at about 50 in a contraflow. letters not necessarily in the right order
Post #61380 24th Apr 2011 2:17pm
Ludzy
So where is the MAF in a SC? I been looking on rave but it only shows location in standard v8 engine. I think I've found it but as I'm nut the best under the bonnet I'm not to sure. As long as a have instructions how to do stuff I'm alright. I'll have to give it a good clean aS I've seen on afew other sites.
Post #61381 24th Apr 2011 2:23pm
Ludzy
Ok so I thought I'd do a quick update as this is abit confusing now.
Drop SC off to the indy yesterday to see what the problem was. Pick up late evening and indy had just cleared codes as nothing conclusive could be found with the car. They cleared 2 fuel pump codes (fuel pump sec circuit high & fuel pump sensor) Explained that issue only happens at high loads. Was told that if/when it happens again bring it back ato see what codes are thrown up. So I get the car and head out to open her up to see if it happens again. So driving at high load (legally honest) and the reduced performance msg flashes up again as expected but this time the mil light comes on as well (not happened before). So limp home and park up. Get my reader out to check codes and get 3 come up:
P0126 - insufficient engine coolant temp (ETC) for stable operation
P0118 - Engine coolant temp (ETC) circuit high input
P2601 - Coolant pump control circuit range/performance
So I drop the car back to indy this morning. Got a call this afternoon and the only thing wrong with the car was that the mil light was on. Indy couldn't pull any codes as nothing was stored even tho my reader got the above codes last night????
So I now have the car back. Indy reckons its the fuel pump but I have to wait and see if the they codes come back to confirm this. According to some figures may fuel pressure is slightly low. Just checked on my reader and no codes present so I'm kind of stuck now as I know if I was to take her out on the motorway the reduced engine performance msg would come back. I did a few print outs of my codes and gave it to em and mentioned the the bulletin about the auxiliary coolant pump that sometimes is cross connected but I dont think they actually took any notice of that. They think its the fuel pump but need more proof but I think its the coolant pump as there the codes that I have got in the last few readings before today.
I would have thought no matter what reader/software is used you would get the same codes come up? Theres is in more detail as it brought up a seatbelt sensor code but for the engine I would have assumed it would be the same. been quoted £500 to change the fuel pump if needed. I think this is covered by my warranty as it covers mechanical and electric fuel pump so that out so bad. So I'm not sure what to do now???
This is some freeze frame data that I got last night when the msg came up. Not sure if this is helpful or not?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Ex FFRR 4.2 Supercharged
Post #62881 6th May 2011 5:27pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
ask your indy if he owns a pressure gauge...... Whistle 2004 black Vogue TD6
Post #62915 6th May 2011 11:06pm
