Home > Technical (L405) > Front bumper camera |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 759 |
A stone chipped my front bumper camera! What are the odds... Can someone help with the part number for my model? Plenty of cameras on (UK) eBay, but I don't know which are compatible with mine (2019 P400e Vogue)... Thank you! |
25th Nov 2021 3:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
try microcat maybe? ... - .- -.
25th Nov 2021 9:24pm |
Yes, I did, thank you, but as for eBay, they only say: LR052028 360° camera for Range Rover L405 from 2013, 6PIN.
25th Nov 2021 9:41pm |
just a thought...can you take the old one out and 'hope' there will be a part number on it.. ... - .- -.
25th Nov 2021 9:47pm |
Thanks, looks like a bumper out job... |
26th Nov 2021 12:10pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1148 |
The fleaBay seller states SDV8 VOGUE SE. PART NUMBER LR052028 - front camara ( ). LAND ROVER. RANGE ROVER. 5 Door Estate. Part Colour. RANGE ROVER 2013 -2021 Mk4 (L405).
26th Nov 2021 8:45pm |
Thank you, I sent him a message! |
26th Nov 2021 9:50pm |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 166 |
OK, I'm going to hold my hands up here and state "I am stupid".
26th Nov 2021 10:01pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Talk to me about these ramps
26th Nov 2021 10:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
A RH camera has been on backorder for some 4 weeks now for my car... |
27th Nov 2021 1:01am |
"The Range Rover has a parking aid system that operates in conjunction with the vehicle's cameras, and gives a 360 degree, detailed view of the vehicle's surrounding area and any obstacles in the vehicle's pathway, when parking. The surround camera system consists of 4 cameras, located as follows: One is located in the centre of the front lower grille. One is located underneath each of the exterior door mirrors and one is located just above the rear number plate. The capacity to display several different views at the same time helps with various manoeuvers, from parking by a curb, to getting in and out of tight spaces. The integrated cameras also provide assistance when towing. Additionally, the 360 degree Parking Aid supports manoeuvering by employing sensors around the vehicle that automatically trigger when Reverse is selected or can be manually activated. When manoeuvering, visual graphics and audio feedback indicate proximity to obstacles. In order to get full benefits from this driver assistance package, customers will need to know how to access settings for both the Surround Camera and the 360 degree Parking Aid. If you wish to have this feature turn on automatically when performing a parking manoeuver, you need to make a selection in the settings. First, select camera from the Touchscreen to call up Surround Camera. Then the Camera settings pop up is displayed. From there, the customer is able to select Default Camera View and then add 360 degree Camera as a default view. " |
27th Nov 2021 7:30am |
Well I have learnt something there!
27th Nov 2021 11:25am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1635 |
Yes brilliantt piece of kit. Comes with rubber blocks for lifting points and droppable end plates. Plenty of line to the control box. 3T capacity. Been faultless for a couple years now but only light DIY use. I think I paid about £1900 delivered (30 miles from supplier). Ordered direct with Strongman. No need for a middle man and great service and support. You only need a Cat C or D breaker (back then anyway - worth checking spec now) and a few litres of LIC hydraulic oil. The only thing I would say is the width is tight. You have to position a 405 exactly down the centre line. Lesser cars are a doddle. The axle stands are just a bit of comfort for me. Well worth it. 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
27th Nov 2021 2:50pm |
I managed to get an answer from the dealer, the surround cameras are all identical and the part number is LR098720, for Land Rover/Range Rover and for Jaguar (again, identical and similar to LR) T4K4171. |
15th Feb 2022 3:28pm |
