![]() | Home > Technical (L405) > L405 4.4SDV8 B12A6-13 (28) Auxiliary heater water pump fault |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
It’s not the same unit as the 322. The Webasto unit was replaced with an erbspacher one. There is much less on them as they seem to go wrong less…..
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
Thank you, I did some digging via Topix and managed to find some info on replacement etc so have ordered a replacement pump (LR039070) for around £140. I've checked all the electrical connections and they seem find so pump is the next step. 2013 FFRR Vogue SE |
Crasher73 Member Since: 19 Jan 2022 Location: Peterborough Posts: 3 ![]() ![]() ![]() |
Hi Martyn,
Hi Mark,
Excellent 👍🏻
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 251 ![]() ![]() ![]() |
i've had this issue also. Do anyone know if the failure is a mechanical issue generally? My warranty company fighting me on it. Warranty Wise.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
I had the same issu on mine - FBH would fire up but never warmed up. Turns out the pump for the FBH had failed - mine was replaced under warranty and its been fine ever since. Ash
Who was your warranty with?
Hi Andrew,
thanks - precisely the sort of problem I'm having - the aux water pump has 'seized', and they're using that one word to say that it's not mechanical but somehow corroded or rusted shut. Fulls service history with correct liquids used etc. They're impossible. --
