Home > General > 3.0 td6 - worth a shout?
LandyGee
Hi all,
I’m very close to dropping circa £15k on a 4.4 tdv8. Have done loads of research about them and had some really useful info from you chaps on here.. However, I have seen a few great examples of 3.0 td6’s (facelift) recently and wonder if anyone has anything to say about them? A little too old now and will need more love and attention or a worthwhile purchase for a lot less than £15k!
Would be interested to hear your thoughts! Cheers!
Post #614060 28th Nov 2021 9:41pm
mjdronfield
Irrespective of how engines etc compare….
I think the big issue is going to be corrosion on the older cars, not brilliant on some of the later ones.
Quite a few older cars are failing MOTs due to structural corrosion near jacking points on the sills.
There is nothing wrong with a TD6, I loved mine, though it was remapped by JE Engineering.
But my 4.4 TDV8 is the longest I’ve ever kept a car…. It’s like an L405 in a different body….
Drive them both… decide what you think fits you best…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #614066 28th Nov 2021 10:10pm
Slow progress
Very different vehicles in some ways. The gearbox is the weak point on a td6, you get the older style dash, mpg is c.22/25 vs 30mpg for the 4.4tdv8, if you go pre 2006 on the td6 tax is cheaper at £340/yr, acceleration is 12am slow to 60 vs sub 8.0 for the 4.4tdv8.
For me I’m getting a td6 to start with until I save up for a 4.4tdv8. Either way check for corrosion on sills and near those rear arches, and service history is key.
Post #614067 28th Nov 2021 10:11pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
I've been the proud owner of a 2005 TD6 for 10 years . LOVE it.
Just coming up to 200,000 kms . Great engine . Drive one, you might be surprised how well it goes.
Only weak point is the GM 5L40E auto, which I have had rebuilt & improved . So put some money aside for a rebuild if it hasn't been done already.
As with any car now getting on to 16 + years old it will need some maintenance . I've just replaced the front shocks/ airbags & rear shocks & all brake pads. More for peace of mind than anything as my suspension fault turned out to be computer related .
No rust over here . Must be all the salt you guys put on your roads.
But now my beloved TD6 has to got as I'm about to purchase a 2017 SDV8 . ( came into some unexpected money ) But still apart from the auto & a few minor niggles I can't fault my TD6 . So don't dismiss them
Post #614096 29th Nov 2021 5:09am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I have run a 2005 TD6 as my daily drive since February 2019 and it hasn’t missed a beat. I have had to replace the front lower arms and a couple of bushes but that’s it apart from regular servicing.
Big enough for the dogs, dump runs and moving various daughters around the country it’s comfortable and capable. I paid £5,500 for it when I purchased it with 97,000 miles on the clock. It now has 115,000 and last week I was offered £6,500, so it has held its value very well.
If you buy one from a Range Rover enthusiast you will probably be able to pick one up that has no corrosion or has had it sorted out.
Jim
Post #614119 29th Nov 2021 10:57am
^ £6500.00, you've just made my day. Thumbs Up Very Happy
Post #614120 29th Nov 2021 11:06am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had my 02 TD6 for 11 years now . 2 previous owners and was 123k miles when I got it and now on 167k so don't do a lot of mileage. It has never had a tow bar fitted and is on it's original gearbox . First thing I did was a fluid and filter change when I got it . Some (but not all) first GM boxes didn't have the issue with the alloy blocks wearing and causing issues and it looks like mine is one of them (fingers crossed) . In my ownership it has had the dreaded rear jacking sill corrosion on both sides re fabricated (£2k) , front prop shaft coupling (1k - missed the recall by 1 week and JLR were not interested !) , replaced carbon brushes in the alternator , replaced starter motor and 2 x diesel injectors along with fitting the vortex oil filter mod for the turbo . It is , I found out , tuned with an add on tuning box fitted . Apart from that and routine maintenance and WaxOyl (think of the forth road bridge - never stops lol) it's a fantastic car and stands on a Ctek MXS10 charger in the drive for when it's needed . If anyone is looking at purchasing a potential TD6 , or any car for that matter , I would recommend putting the registration number in the government web site and look at the vehicles MOT history - it can be quite an eye opener Smile
Post #614123 29th Nov 2021 11:21am
mercs600
Oh , forgot to add , also had the main thermostat by passed with the renault in pipe mod , rather than strip the engine apart to replace the original Smile
Post #614125 29th Nov 2021 11:23am
