Home > Maintenance & Mods (L322) > Help choosing a battery
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Looking to replace my battery as it’s starting to fail in the cold weather I currently have a s5 015 it’s been on 5 years now and failing so looking for a good replacement any help would be great
Post #614117 29th Nov 2021 10:50am
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
'Bens Garage' on YouTube has recently put out a video about replacing the battery in his TdV8 again, he had some recommendations, only one I can remember is using an AGM battery even without having stop-start. Might be worth checking vid as I wasn't concentrating on it at the time. 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #614126 29th Nov 2021 11:34am
JayGee
I wouldn't put an AGM battery on an earlier car as the alternator and charging system needs to be a 'smart' version which is only found in the >MY10 cars. 2012 TDV8 Vogue (L322)
Post #614139 29th Nov 2021 1:17pm
dingg1
Put one on my 2007, no issues whatsoever and the best thing to do imo as it's been perfect for over 5 years now, was going through a type 020 every 2 years previously Cool
Post #614141 29th Nov 2021 1:22pm
cass
+1 for fitting an AGM, I put a second hand AGM on my 07 TDV8 when I bought a new battery for my 2011 TDV8. It cured the problem of the car not starting if it was left for more than 3 days.
Post #614158 29th Nov 2021 4:15pm
andyfid
The only thing is mine is a 2003 so would a amg battery be ok for charging
Post #614169 29th Nov 2021 6:09pm
RJPotts
https://mechanics.stackexchange.com/questi...gm-battery 2010 Range Rover Autobiography TDV8 Santorini Black
Post #614171 29th Nov 2021 6:17pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
An AGM battery with Lead Acid charging system will only charge to around 85%. AGM batteries need a higher voltage to fully charge.
Yer pays yer money, yer makes your choice!
A like for like capacity AGM battery will really be a downgrade step from a lead acid in terms of capacity, i.e. if it was a 100ah Lead Acid battery you would end up with 85ah capacity with AGM 100 ah battery. It would have more CCA in all probability so you may see better cold starting with an AGM, just not be able to run radion / lights / FBH for as long. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #614181 29th Nov 2021 6:57pm
searching on google comes up with that you can replace a lead acid battery with an agm type with no issues.. ... - .- -.
Post #614182 29th Nov 2021 7:07pm
Yip, fitted an AGM to my 2008 and no issues at all Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #614183 29th Nov 2021 7:09pm
AJGalaxy2012
Correct, you can BUT you will have lower capacity if the charging system is configured for lead acid. It all depends whether you need more CCA or longevity which way to go, AGM offers NO advantage really compared to Lead Acid if the car is configured for lead acid. BMW i3 Electric Car
Post #614190 29th Nov 2021 7:51pm
andyfid
Yeah I think I am sticking with the lead acid I had the Bosch fitted but think I might try the vatra heavy duty this time
Post #616378 14th Dec 2021 7:46pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
andyfid wrote:
The only thing is mine is a 2003 so would a agm battery be ok for charging
On My 2003 TD6 I had two 100ah AGMs, one main and a second in the rear. Both batteries charged fine with the car alternater. The same Aux battery was also in my P38a and must be well over 10 years old, I removed it when I sold the TD6 and its sitting in my garage as a spare. It still sits at 12.8v and tests at 1005cca. The brand is Oddessy Extreme, quite expensive but for me well worth it.
https://www.odysseybattery.com/extreme-series-batteries/ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #616413 15th Dec 2021 3:01am
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I have a bosch agm battery in my 2009 3.6 and no problems whatsoever, its been in 6 yrs and still starts every time. 2009 Vogue SE Zermatt silver
Post #616499 15th Dec 2021 4:01pm
Slow progress
One thing to note is the Bosch and Vaarta batteries are made on the same line with different labels….do you can save a few pounds here!
Post #616536 15th Dec 2021 8:10pm
