Home > Maintenance & Mods (L405) > Gearbox flush
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Gearbox flush
Thanks to Bodsey for his quick response and flushing not only the gearbox but the transfer box and diffs. Bow down
I had not realised how clunky my gear change had become but it is now so smooth I can hardly feel it change. Another job ticked off! 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #611503 3rd Nov 2021 5:04pm
DrRob
He's a legend Bow down 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #611505 3rd Nov 2021 5:11pm
AndyViking
United Kingdom 2017 Range Rover SVAutobiography SDV8 Corris Grey
What’s the recommended (by Bodsy!) interval for an L405 flush? He did my old D3 and it was like a new car.
Cheers
Post #612997 18th Nov 2021 12:53am
Mikey
Between 50-75k, according to ZF Thumbs Up
Post #612999 18th Nov 2021 6:16am
AndyViking
Thanks Mikey (as in DiscoMikey?)
Sounds like a trip to Ian after the winter is required. 53k and already starting to feel a little sharp. Transfer cases etc being done on the next service in a few weeks time as well.
Cheers
Andy
Post #613005 18th Nov 2021 8:27am
DrRob
Martin Hind at Dartford Transmissions and Autocare is also close to you in Kent....
Bodsy can be booked for weeks in advance due to demand but it's very convenient having him on your drive 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613007 18th Nov 2021 9:46am
AndyViking
Thanks DrRob
I have used Ian’s services before on my D3 - he is a top bloke so will probably link up with him on one of his next SE days
Cheers
Andrew
Post #613015 18th Nov 2021 10:42am
ncosty
United Kingdom 2015 Range Rover Vogue SE SDV8 Loire Blue
Going rate for a gearbox flush?
Hi all, Just wondering what an 'appropriate' or reasonable price would be to replace transmission oil (2015 SDV8).
From a local gearbox specialist I've been quoted:
£50 per litre - 9 litres required
£193.39 - gearbox filter
£120 - labour
Total - £763.39
Sound okay?
Post #614272 30th Nov 2021 3:49pm
Sonearly
Would get more quotes, specialist in Northamptonshire quoting £450 inc filter
Post #614276 30th Nov 2021 4:16pm
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
You do need to be careful that you are comparing like for like quotes, a genuine ZF filter and oil will always cost a lot more than so called “equivalent” bits.
Only you can decide if the saving is worth the risk.
Post #614282 30th Nov 2021 5:00pm
ncosty
Noted with thanks chaps. I'll take your advice. I'll check my quote is for 'genuine' parts/products and then get a couple more like-for-like quotes. Keep it oem as far a possible.
Post #614289 30th Nov 2021 5:38pm
