Home > Technical (L405) > Climate control question.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
So I am used to climate control from previous, just come from a D3. The RR seems much the same, but. When it is set at a temperature, the blower is constantly on, at some speed. I find that this dries the air, and often I just open the window a crack to let in fresh air. Am I doing something wrong ? 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #614147 29th Nov 2021 1:26pm
CS
In addition to setting the temperature you can adjust the fan speed so it does not blow as hard. Climate control is best with the windows closed. Only Range Rovers since 1988
Post #614189 29th Nov 2021 6:50pm
I just press the Auto button & it seems OK
Post #614192 29th Nov 2021 7:06pm
Landphil
In Auto the blower speed is related to how close the temperature in the car is to the temperature you have set. If you have different temperatures set on the individual controls that will affect blower speed. Opening windows, at this time of year, will keep the blower on for longer.
I set 20 on both sides and Auto. I find I never need to change it and the blower is not a nuisance- at least not to me.
Post #614199 29th Nov 2021 8:16pm
supershuttle
I also set at 20 and auto and just leave it. The only thing I've noticed is that eventually the car feels cold so I need to move it up a little to 23 - never noticed the fan. I don't think I ever open windows other than to pay for my McDonalds breakfast. Geoff
Post #614209 29th Nov 2021 10:29pm
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
I've had this problem and in my case it's been caused by my young granddaughter playing with the rear a/c controls.
I have to check that the rear settings are off when there's nobody in the back of the car and then there's little or no fan noise. 2017 SDV8 Autobiography
Post #614210 29th Nov 2021 10:40pm
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
Worth noting that you can change the automatic fan speed from low>medium>high.
Post #614257 30th Nov 2021 12:34pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Put air con in Auto and press sync on air con menu.
Now all the car will get to the temp you want, this will cancel out your little one in the back fiddling with the temp.
once car reaches temp fan will go down in speed and just cycle to keep constant temp.
Post #614333 30th Nov 2021 11:00pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Do you have to turn "sync" off to allow people in the back to change the temperature themselves? What do I put here then?
Post #614342 1st Dec 2021 7:21am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
No. Their actions simply cancel the sync.
Post #614365 1st Dec 2021 12:20pm
GAC23
And - possible daft question - do I have to turn sync back on, or will adjusting the driver's temp do this? What do I put here then?
Post #614383 1st Dec 2021 2:38pm
adara
Passenger action cancels sync. So yes, a new sync press is required.
Post #614386 1st Dec 2021 2:52pm
GAC23
Thank you. What do I put here then?
Post #614391 1st Dec 2021 3:08pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
This made me smile, when I purchased my 2014 a few years back I clearly remember how my heart sank when I got home, sat in the back and discovered the entire rear heat/cooling control & display panel was stone cold dead..!! I read the manual with vigour hoping to find it was just a matter of selecting some or other function but alas no such luck...
So being unable to sleep I got around to stripping the rear control panel which was surprisingly easy to do, only to find that my 'fault' was a completely disconnected plug.. Quick reconnection brought all the controls back as they were meant to be..
Turns out the previous owner had young kids too, and while the fattie was not used much, I guess he must have got tired of them playing with the buttons back there...
Post #614529 3rd Dec 2021 4:23am
