![]() | Home > Technical (L322) > Gearbox ticking noise |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
This morning I started the beast and upon selecting R , the gearbox began to make a ticking noise in sync with the RPM. It resembled the noise of fan blades hitting onto a plastic tab or bicycle wheel spokes caught up a twig or something. Selecting N the noise stopped. I'm not sure if there was a little bit of noise in D at first too, maybe not. Drove for a Km and checked again by selecting R, noise was barely there. Drove for another Km and noise was gone. All shifts are smooth as ever, no shudder uphill no loss of drive on R.
This morning again...
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Sounds like a box out job too me sadly.
No, just on R and only in the morning, when cold. Goes away if I select R having driven for a few hundred meters. I can reverse 100 times during the day without any noise reappearing. No thud, no shaking no shift delays. All is working normally even while this happens. Does it sound like something you have encountered before? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
First thing I'd do is get the gbox oil changed and make sure the level is correct, always try the simple solution first
Agreed. Booked for gearbox oil and filter change on Thursday. I'd have these done anyway as I'm nearing 50K km since last done. |
Noise hasn't returned during the week. Oil level checked and was okay. Today changed the gearbox oil. No debris other than the usual stuff on magnets, old oil looked bright enough...Gear shifts had always been smooth but, they do feel even smoother now, almost imperceptible |
