Home > Technical (L322) > 2010-2012 Reverse Dip Mirror Cancel and when towing?
garyRR
Pages 71 to 78 are missing in the downloadable owner's manual.
Can anyone tell me how to quickly cancel reverse mirror dip on a 2011? On my 2006, if I flicked the mirror select switch, it would cancel. On my 2011, it doesn't and simply lets me adjust the reverse dip mirrors (probably because both dip in reverse whereas on earlier cars, it was just the passenger side).
Also, does anyone know if this system cancels when towing I.e. if a trailer is connected, does the reverse dip not function, just like the rear parking sensors turn off? (I have fitted and hard coded my tow bar) 2015 Range Rover Autobiography 4.4 SDV8
Post #615115 7th Dec 2021 12:31am
rjff
Go to
Instrument panel main menu from steering wheel button
vehicle set up
reverse dip mirror
untick
done
Should work
HTH
Can't help on the reversing with trailer, can't remember and 'van stored off site. Cheers
Richard
Gap IIDBT
Post #615144 7th Dec 2021 10:07am
garyRR
Yes, I know how to permanently turn on it off however, it obviously takes 5-10 seconds to do and that doesn't quite work with traffic behind you.
I wondered if there's a way to toggle quickly, like there is on the older versions. 2015 Range Rover Autobiography 4.4 SDV8
Post #615199 7th Dec 2021 4:20pm
bishbosh10
They still dip with a trailer connected. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #615217 7th Dec 2021 6:25pm
rjff
Sorry ,
obviously didn't realise from your post that what you needed was instant change.
Perhaps somone with more knowhow will reply. Cheers
Richard
Gap IIDBT
Post #615243 7th Dec 2021 10:50pm
mjdronfield
This might not be of much use, unless you are a good reverser…. But if you exceed 7mph in reverse, the come back from the dipped position automatically….. Power !!!
Told you it wouldnt help, but it’s true.
I reverse up to my garage and sometimes they stop dipping and I have to slow down again. Not with a caravan on though…
In all seriousness, I’ve not tried the button in the other position, that worked on my TD6, but you’ve already tried that.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #615259 8th Dec 2021 8:51am
mjdronfield
Just nipped out, as you say, the button doesn’t do anything now. Looks like you will have to use the instrument cluster menu…. And the time that takes….
Orrrrr…. What if you adjust the dipped position to be up at the normal position, that way, the car thinks it’s dipped them but they are still where you want them?
Have to reset for without the caravan obviously.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #615292 8th Dec 2021 12:10pm
