![]() | Home > Technical (L322) > 2010 L322 Glovebox Trim |
| Graham4242 Member Since: 26 Sep 2021 Location: Dubai Posts: 41
Sorry I can’t help you with the part number but I’ve had the same issue on mine. The plastic hook that goes through the hole can be gently bent (leg of the hook) while it’s out of the hole (in its lowest position). Then guide it back into the hole. At least this worked on mine. Current
| tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69
Thanks Graham. I'll give it a go and maybe try softening it with some verryyyyy gentle heat. |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Bend it back. Works a treat. Careful with heat. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
+1 for bend it back
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
And worked for me on several occasions... |
