Home > Technical (L322) > electrical library
electrical library
in a rar format for download,
http://www.fullfatrr.com/gallery/albums/us...%29%29.rar
in wiki as well.. ... - .- -.
Post #275502 12th Aug 2014 5:29pm
stephen44
United States 2005 Range Rover HSE 4.4 V8 Java Black
Thanks for this - i opened the doc and it was not clear which model years it covers - I saw it was published in 2002
Stephen 2005 L322 HSE (usa) Stephen
USA (originally from London) - 2005 L322 HSE
Post #275511 12th Aug 2014 6:50pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Re: electrical library
in wiki as well..
Hi Stan,
I don't suppose you know of a newer version of this do you?
Thanks & best regards
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #615528 9th Dec 2021 6:42pm
mjdronfield
I thought for the later cars, it’s part of the Workshop Manual, that’s in the Wiki for download.
90% sure….
Just checked… should be in there….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #615529 9th Dec 2021 6:45pm
RJPotts
Thanks...... We might be thinking of different things though........
I've got the wiring diagrams (within the 2010-2012 Workshop manual) but where for example that shows connector C0232 into the analogue clock the electrical library would show me where that connector is, how the pins are laid out and the wiring colours;
The file above is great for some stuff but obviously doesnt include changes / additions since 2002.
PS, screenshot from DS File / a Synology Diskstation?
Best regards
Post #615537 9th Dec 2021 7:23pm
mjdronfield
Ah, see what you mean. I used the old docs and RAVE when I had my TD6.
Yes, it’s from DS File. I have a 16TB Synology NAS i store stuff on. DS415+.
You would have thought they should still be in there. Not sure….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #615542 9th Dec 2021 8:16pm
RJPotts
Pity the details are in a separate doc but I suppose that makes it easier to refer to the diagram and the library at the same time.
Thought so..... I've got a DS418, would be 16Tb on 2 drives but I decided to set it to RAID1 so of course only get half. One of the best things I've ever bought, streets ahead of the WD thing I did have. 2010 Range Rover Autobiography TDV8 Santorini Black
Post #615545 9th Dec 2021 8:23pm
peternicholls
Hey, I’m struggling to find how the front electric fan is wired up in my 2007 tdv8 3.6. None. Of the electric guides match up with the details at all. I have the engine wiring and it just shows and ecm pin out to ‘control unit - cooling fan’ and from there is a mystery! Any insights please? Error fault code on this
Post #652370 2nd Jan 2023 9:14pm
Phoenix
Have a look on 'engine cooling' rather than 'electronic engine controls'.
Post #652371 2nd Jan 2023 9:25pm
peternicholls
that is indeed what I have been looking for. All the info I can find is on the viscous fan. Nothing about the mysterious box called ‘control unit - cooling fan’ (D241) on contact C0005-4. This is clearly just a control signal wire. But details about the front cooling fan are almost non existent? I am dyslexic, so please bear this in mind. It clearly is getting in the way of finding hard to find info
Post #652375 2nd Jan 2023 9:41pm
Phoenix
Second page, where there are optional circuits marked with } then follow the circuits marked 'DV8'
https://www.fullfatrr.com/gallery/albums/u...ooling.pdf
Post #652377 2nd Jan 2023 9:56pm
peternicholls
Thanks. How did you find this? Was there a direct link in the wiki? Why isn’t it clearly laid out to find? Everything is only organised once you know where to look. Electric diagrams should be under electric diagrams.
Post #652381 2nd Jan 2023 10:27pm
peternicholls
How can I find all the diagrams for this period in one place? It’s not logical where to look and I’m having to rely on others to show me.
Post #652382 2nd Jan 2023 10:30pm
peternicholls
Sorry another question? How do you find soldered joints? None have gone so far as I can tell, but are they randomly located? Or is there a guide for this?
Post #652383 2nd Jan 2023 10:34pm
Phoenix
I downloaded all the relevant diagrams for my L322 from Topix whilst I still had unfettered access, you can buy access for a day for a single Model / VIN for a relatively small cost and you're free to download as much or as little as you want within the time period you've paid for.
Soldered joints are marked 'SJ' they're supposed to be marked with distance at the connector but in reality, not many are on LM circuit diagrams
Quote:
Wire length (Power and Ground Distribution only)
The wire length (in millimetres) is displayed after the colour and cross sectional area; for
example, SR,0.35,480. In this example, the figure, 480 indicates the approximate position of
the harness splice is 480mm from connector C2335.
Usually they need to be exposed 'manually' or can sometimes be 'seen' using specialist kit like a Time Domain Reflectometer, or an Infra-Red camera. In reality, there are few problems with SJ's, the ones that are problematic tend to be well-known within the workshops and located with the minimum of fuss & time once confirmed through tests.
ETA - an example of SJ locations, from the 'battery mounting and cables' diagram - a much underused but very useful sheet.
Post #652385 2nd Jan 2023 10:52pm
