![]() | Home > Technical (L322) > Seatbelt Warning Chime |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Anyone know if IID can turn this off and if so where it is in the programming?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
not seen this question for a long while..
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Have a look on Fleabay, seat belt blanks, just a couple of quid, pop in , and off you go !! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
Stan is right, turn the ignition on, then plug in and unplug the seatbelt 10 times and it's disabled |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
It does work on the later cars and you can enable it again in exactly the same way.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
worked on my 2011 |
Tried the insert/remove as suggested and it didn't do anything, certainly didn't hear any bong sound.
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
Worked on my 2011. Tried a few times before it finally worked. You have to do it quite fast. 2011 Vogue SE TDV8 |
