Home > Maintenance & Mods (L405) > Squeaky Tailgate Strut(s)
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
My tailgate struts often make a nasty squeaking sound.
It's worse when the tailgate's closing.
Garage I bought the FF from said "lots do that in the cold weather, you need to WD40 them".
Are they right, or is it a case of, "they would say that, wouldn't they"? What do I put here then?
Post #615705 10th Dec 2021 4:53pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
WD40 is a water dispersant. I would use (and I did) a silicone based spray and it worked for me...
Post #615720 10th Dec 2021 5:50pm
And use the same silicone on the door rubbers to stop them freezing Thumbs Up
This worked for me - https://www.wickes.co.uk/FloPlast-40ml-Silicon-Spray/p/175634
Just to confuse things, there is a WD40 version, but it's not regular WD40 - https://www.wickes.co.uk/WD-40-Specialist-...l/p/144012
Post #615724 10th Dec 2021 6:08pm
GAC23
Thank you both very much.
Have just ordered the WD40 silicone spray. What do I put here then?
Post #615725 10th Dec 2021 6:09pm
