![]() | Home > Technical (L322) > I was told to steer away from a 4.4 TDV8 and get a 3.6 TDV8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3298 ![]() ![]() ![]() |
I didn’t say ‘using’ the engine causes soot and I’m not mistaking anything. There is no engineering scenario where increased load and stress on components equals less wear or increased service life. As said before the killer conditions of modern diesels with egr and dpf’s is short stop and start urban trips where the oil temp never gets high enough for long enough and soot burn off’s in the dpf’s are partial or delayed. I’d take a modern high mileage diesel that’s been sat on the m-way at 70 for most of it’s life over a low mileage urban runaround that’s been given a weekly ‘Italian tune’ any day and everyday…… 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
DPFs need to get hot enough to be able to do a Regen. A 20 mile motorway trip once a week is sufficient to keep them clear.
I disagree there is any engineering need to regularly clear oil buildup in the 2nd turbo. You may not like the smoke if you regularly like to drive hard but it’s not detrimental to engine or component life. 2012 TDV8 Vogue (L322) |
Oil in quantity reaching the combustion chamber will damage the cats and DPF. You don't want to be suddenly burning off a quantity of oil which has accumulated in the turbo, as this will be sure to shorten component life and certainly going to shorten turbo life.
By what process is a short burn of oil worse than a long burn of the same amount? As long as you are using low ash oil ( as you should be) there is no issue to the CAT or especially the DPF. All turbos leak some oil as they operate anyway and excessive oil leaks due to worn seals or blocked drains is a separate issue. No MOT test involves a full load test so it won’t fail on this. I know it’s a design flaw but IMO it’s a ‘cosmetic’ issue. For some who regularly ‘need’ >2400rpm then sure you are saving yourself the embarrassment at the cost of increased ( however small) component wear and stress of a regular Italian tune. With these cars now getting to be a minimum of 10yrs old I’d suggest for prolonged life it’s wise not to stress any component any more than absolutely necessary and 700nm is a lot of stress on tap…….. 2012 TDV8 Vogue (L322) |
I'm going to end it there because I'm not getting into an argument just over what I recognise as a difference of opinion. 2015 Range Rover Autobiography 4.4 SDV8 |
Yes simply a difference of opinion and everyone uses their vehicle their own way and what’s right for some is not for others |
Yes, that's right. It was designed for the F-150 but Ford decided to continue with petrol in the American market and the 4.4 V8 diesel went into the Range Rover instead. I think it was designed to tow 6 tonnes but because we're Europeans and weak, the maximum cars are allowed to tow is 3.5T.
Also the kerb weight of the 4.4 is less than the 3.6. I'd love a V6 as I (obviously) don't need the full power of the 4.4 but I just don't trust the cranks. The main reason I didn't get a D4 was the crank issue and it's not the 2nd, 3rd hand experiences I've read it's people I have met personally who have had this happen. New cars with 200miles on them and older ones with 100k+ miles. Best explanation I've seen is that it's a 4cyl size block with 6 cyl in it and thus has wafer thin crank webs.... 2012 TDV8 Vogue (L322) |
LR did fix the crank issue - at the workshop, they were saying they don't really see them coming in for fix anymore.
How did they fix it? The person with 200miles on it was offered a new engine but said they wanted a new car as obviously a car with a replacement engine is worth less when you come to sell it so if the majority of customers are doing this then the workshops won't see these failures..... 2012 TDV8 Vogue (L322) |
