Home > Maintenance & Mods (L322) > Oil leak after belt broke |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
Crank oil seal. 2006 4.2 SC |
11th Dec 2021 9:59am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2790 |
Mine was replaced when they did the waterpump and aux belt and tensioners. 2012 TDV8 Vogue (L322) |
11th Dec 2021 11:00am |
Pjtaroni Member Since: 21 Aug 2021 Location: Loughborough Posts: 37 |
As above, probably a piece of the old belt in there. Need to strip down and check and rectify ASAP, will get worse very quickly. Had a tdv6 in a discovery chuck its seal out, emptied the entire sump in minutes |
31st Dec 2021 12:14am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Is this a common issue? I’m midway through changing my belts, pulleys, alternator, ac compressor and water pump. Do I need to consider this as a preventative measure? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
31st Dec 2021 9:35am |
I’ve not seen one leak without being damaged so it’s down to your own preference whether you change it, just wether you take the risk damaging the new seal on fitting and then having issues after |
31st Dec 2021 9:40am |
Mjak42 Member Since: 11 Mar 2021 Location: Warragul, Victoria Posts: 15 |
Yes more I drove worse it got, stripped it down and found a huge amount behind pulley like a birds nest, seal was badly damaged easy to remove, bit tricky getting the new one on without damaging it, I found if I had the key way at the bottom I could put seal onto key way first gently lifting then slipping it over the shaft, have also found crank pulley is wobbling which I never noticed my mechanic reckons that’s what started my problem, the wobble probably led to belt coming off, new pulley arriving Tuesday, refit and hopefully be alright then, will check and see if new seal is leaking and I didn’t damage it putting it on, Ffr-lover if your belt broke it may have gone behind pulley but it may not, need a strong rattle gun to get it off, I used a Milwaukee fuel 18. Check photo out of what was behind pulley
31st Dec 2021 11:02am |
Blimey, that is quite a mess!
31st Dec 2021 12:27pm |
Looks like you should be alright, motor side of belt is still intact, shed some light on your pulley take a photo like this one, I never noticed when I took photo, if you look in the top slot that is the belt behind pulley, just make sure yours doesn’t look like mine
31st Dec 2021 12:37pm |
No visible signs of any debris there!
31st Dec 2021 12:44pm |
Looks good, can’t wait to drive mine again been 3 weeks so far 2011 Voque 4.4 TDV8 |
31st Dec 2021 1:06pm |
RMac73 Member Since: 30 Jul 2022 Location: Inverness Posts: 10 |
I've got the oil leak after a pulley seized and the belt shredded round the fan...
25th Apr 2024 9:53pm |
Rmac 73 hardest part of strip down was getting to all the bolts on the radiator shroud, made my own tool to hold the fan bolts whilst undoing fan bolt, you’ll need a huge breaker bar to get crank pulley bolt off, get a new bolt with pulley your supposed to take starter out and a special Landrover tool to hold toothed plate(forget what it’s called) but I just used a stubbie impact driver instead, didn’t have to take radiator out, I marked pulley with white paint stripe then just tightened it up gave it a rest then went again, give it a good go then mark side of bolt to match pulley and I used a small adjustable mirror to check it, so far it’s done 20,000 klms and hasn’t moved, make sure you use some Loctite on it. 2011 Voque 4.4 TDV8 |
25th Apr 2024 11:28pm |
Cheers buddy - will look into it 👍 |
26th Apr 2024 8:53am |
