![]() | Home > Technical (L322) > New tyres fix my Range Rover Vogue gearbox problems |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Excellent news, pleased it's sorted.. |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Classic case of different wear patterns and slightly different rolling circumference as a result on the same axle completely confusing the gearbox, I had this on my old e39 528i in the rear- baffles me for ages until I got a new pair of tyres for mot- completely fixed the issue! 2009 (2010 MY) 5.0 Supercharged Autobiography
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 189 ![]() ![]() ![]() |
One to pop in the knowledge box. Cheers |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
Wow, I see the threads on Mega Flushes etc and wonder how a dealer can get this so wrong, did they do this themselves or a 3rd party? Do these gearbox manufactures recommend such flushes? I hope you bill them for the new tyre's? as the originals are clearly not fit for purpose. 2018 SE SDV8 4.4 Byron Blue |
ZF do not recommend flushing and that was enough for me to not go with a megaflush. 2012 TDV8 Vogue (L322) |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 800 ![]() ![]() ![]() |
thats Interesting, I was advised to have my gearbox flushed but I thought I would just drain the oil two or three times when I did the engine
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 261 ![]() ![]() ![]() |
Straight from the horse’s mouth:
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Interesting. I wonder why they specifically recommend against it. Especially has so many have had it done and its worked wonders. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
A normal 'service' works wonders as well...... 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2727 ![]() ![]() |
I wonder if the ZF comment was referring to using a flushing oil rather than using the correct fluid.
Porthbay Member Since: 18 Sep 2021 Location: Yorkshire Posts: 7 ![]() ![]() ![]() |
In the case of my car, when I took it to the specialist for the mega flush the only problem was the 5 to 6 gear change. The guy explained that 9 out of 10 cars could be successfully mega-flushed. It seems that mine was the tenth. When it came out of there, any revs above about 2000 locked the transmission completely. Later, the gearbox garage said that all the clutches had been completely damaged. My car had less than 100,000 miles on the clock.
By "locked" I mean put it into limp mode. |
The E-clutch is on the same shaft as the pump with its white-metal bushes and the effect is the clutch not locking quickly enough when trying to use 5th or 6th due to inadequate pressure from the leaking pump, which then triggers limp-home mode. My D4 had done 120K KMS of country driving with me always guarding against unnecessary torque converter slip, but too many kms for the worn white-metal bushes after the oil and filter change on a gearbox that had no issues before the oil (LG6) change. |
