Home > Technical (L322) > Adaptive Headlights & Cornering lights - standard?
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
I have cornering lights on my AB (fog lights coming on relevant side), but don't think I have adaptive lights..........
How would one check?
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #616503 15th Dec 2021 4:38pm
normally when you switch the headlights on they should 'dance' whilst they adjust then selves.... ... - .- -.
Post #616504 15th Dec 2021 4:40pm
mm289
Not seen that so maybe need to have a poke around Very Happy 2011 TDV8 AB
Post #616506 15th Dec 2021 4:42pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Cheers,
MM
As previously mentioned, they react to the steering input and turn into the corner. It is quite obvious when you are driving at night time especially on country lanes.
On the L322 it is not the 'dance', I think the dance started with adaptive beam headlights. These are just swivelling headlight, which is good enough, was rare at its age, although citroen did that many decades earlier Mr. Green
Post #616508 15th Dec 2021 4:51pm
my 2008 L322 had these headlights and they do indeed 'dance'.... ... - .- -.
Post #616511 15th Dec 2021 5:12pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Yep they definitely dance on my 2006 Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #616516 15th Dec 2021 5:38pm
Bl4ckD0g
We are talking about the specs and spec list of the 2011 model Wink
Post #616524 15th Dec 2021 6:27pm
they dance or initialise on the 2010-2012 as well..
from the WM,
Initialization Procedure..
When the AFS control module receives an ignition on signal, the control module performs the initialization procedure which ensures that the headlamps are correctly aligned on both their vertical and horizontal axes.
The AFS swivel initialization starts less than 1 second after the headlamp leveling initialization is activated to ensure that the headlamps are at or below the 0 degree position in the vertical axis, thus preventing glare to oncoming vehicles.
The AFS swivel initialization is completed in less than 2.5 seconds. The LH and RH AFS actuator motors are powered from the 0 degree position to a small movement to the inboard position, then another small movement to the outboard position and then back to the 0 degree position.
Post #616528 15th Dec 2021 6:55pm
Bl4ckD0g
They don’t do that on mine at all. Yet the functions work just fine.
Post #616533 15th Dec 2021 7:36pm
Pysta
Slovakia 2011 Range Rover Vogue TDV8 Fuji White
Can confirm, they don't do the standard dance on my '11 neither. Compared to other cars I had with AFS, the cornering LED comes on too soon for no good reason (even at slight turns at standard speeds around 50km/h), and the xenon swivel is not too obvious - similar to VW, but very unlike to PSA/Ford who throw the lightbeam around as if you're out fox hunting.
Post #616977 20th Dec 2021 10:36am
