Home > Maintenance & Mods (L322) > LED Reverse light upgrade
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hello all
I know this has been asked in the past but many of those posts are now quite old and the links no longer work.
I ordered from a seller on eBay who claimed they worked on the L322 but I found that they were too long. They measure 34mm.
I have found another seller selling LED's that he says are 30mm long. Before I buy another set can any one confirm what the maximum length should be? or have a current link to ones known to work.
Many thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #616737 17th Dec 2021 4:27pm
this thread should help,
https://www.fullfatrr.com/forum/topic54578...rse+lights ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #616739 17th Dec 2021 4:40pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
There used to be a group buy thread until someone on eBay started selling them at a much lower rate.
According to others these fit:-
https://www.ebay.co.uk/itm/253516614363?mk...eab47e7196
Hope that helps
Ian Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #616744 17th Dec 2021 5:55pm
bigbo
Stan - Thanks, I saw that thread.
Ian - Those are the ones I am currently looking at so good to get confirmation that they will fit.
The current supplier has just got back to me, wants a picture of my original against his. So I'll do that tomorrow and see what he has to say.
Thanks
MG TF 2003
Post #616749 17th Dec 2021 6:44pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Hope that helps
Ian
By coincidence, I ordered a set of those yesterday, will reply here when they arrive / have been fitted.
PS, aren't the standard reverse lights woeful! 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #616758 17th Dec 2021 7:45pm
bigbo
Candles!
I tried reversing off my drive the other night and couldn't see a thing, that's why I'm looking now Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #616760 17th Dec 2021 7:58pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I can confirm they fit however you will get the odd strobing effect when the car does a light check.
I'll get some pictures tomorrow night for you as the old one has the reverse leds but the new one don't. Would say I'd get some tonight but after 8 double glenfiddichs that probably ain't gonna happen haha
Post #616782 17th Dec 2021 11:19pm
mjdronfield
I fitted higher watt halogens to my TD6, but over time, they started to melt the plastic lens from the inside, so had to go back to standard.
Got LEDs in my TDV8 - bought when members got a batch of ones that fitted… you prob read a previous post with it on.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #616785 17th Dec 2021 11:34pm
Tiprat
I looked at the available options for my reversing lights and in the end went down the root of a pair of slimline led spotlights, hard wired, to the wring loom on the reversing lights. Then ran the cable along the interior body work in the wheel well, out through the rubber grommet there and positioned the spotlights in the bottom of the rear bumper. So when I select reverse it throws a great deal if light into the ground and not into anyone behind me Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #616826 18th Dec 2021 4:06pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Hope that helps
Ian
Fitted a set yesterday and they work a treat
Post #616827 18th Dec 2021 4:07pm
Bean19844
Sure you can work out which one is which
Post #616840 18th Dec 2021 6:01pm
supershuttle
I swapped mine out, no problem, and much brighter. I should add back in the days I had an L322. Geoff
Post #616869 19th Dec 2021 8:47am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Well, I fitted LED reverse lights to both of our L322's and yes, the lights are very much brighter. Are they better reverse lights? Not much to be honest, they're still cra*p. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #616870 19th Dec 2021 8:50am
Bean19844
Trouble is the reverse lights are in the wrong place too make a difference. When you reverse you look in the wing mirrors and considering the reverse lights are no where near them well it's not surprising they don't make much of a difference I guess
Post #617404 23rd Dec 2021 9:46pm
RJPotts
I would second that......
I usually reverse onto my drive, between two black metal gateposts. At night there's an element of guesswork, unfortunate as the gap if I dont fold the mirrors is about 1/2" on each side. For the time being I've started putting the rear fogs on, going to order a couple of reflectors for the posts. If that doesn't help then when I get round to putting a tow-bar on I might use the armature to mount a couple of additional LED lamps.
I don't remember the reverse lights on my first L322 being this bad. 2010 Range Rover Autobiography TDV8 Santorini Black
Post #617814 28th Dec 2021 4:06pm
