![]() | Home > Maintenance & Mods (L322) > Oil Cooler / oil return leak running onto transmission pan? |
damonky Member Since: 24 Apr 2018 Location: Devon Posts: 19 ![]() ![]() ![]() |
Hi All,
Thanks JayGee, was literally adding the o-rings to the original post. ( wasn't there when you replied)
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3334 ![]() ![]() ![]() |
The transmissions don’t typically suffer leaks but a transmission service should be on your list of to-do’s for a new L322 owner. 2012 TDV8 Vogue (L322) |
Will go back to the dealer in a mo. Vanstones in Cornwall seem to have serviced it in the past, and only 50 mins down the road, So will get it booked in for that transmission service, see if the dealer wants them to do the leaks at the same time.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4347 ![]() ![]() ![]() |
I’d say that’s 99% oil cooler gaskets and the O rings. Get it back to them and request a new oil cooler is fitted. They can warp so just doing the gaskets risks a future leak. O rings = fit Viton ones. All in the Wiki under Engine section
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
get the oil cooler and coolant bottle changed. Here is my bill. it was £600-700 + 7 hrs labour. I also had the transmission and diff oils done. you'll never need to worry again. mines been perfect since.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Looking at your mileage, it’s probably odds on to be the oil cooler, also, if the gearbox hasn’t been serviced then to be honest, it’s about time to do so. Whether you go for a mega flush or just an oil & filter change, the choice is yours. I had mine megaflushed in year one of ownership & oil & filter in year two, think I had a slight weep from the gearbox pan as well, so you can kill 2 birds with one stone!😀
Thanks all for the replies and help. Made me smile this morning, community is half the fun of owning an iconic car for me.
Keep us posted |
