Home > Technical (L322) > L322 Key Turn does not crank
paddylimbo
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
HI
got my Bloomin 2002 l322 4.4. been running ok then the other day the key turns ignition lights come on turn it and does not crank the engine. checked and the gear selector light wsa not lighting up so went for the tcm module, found a seconhand one on e bay and ordered a new fan in case that was what cooked it. disconnected the battery fitted new module. gear selector light came on and car started.result !!! no!!!!! turned it off went to start it again no gear selector light and back to bloomin square one. disconnected the battery to see if it was re-boot issue but no joy, any suggestion what to check and try please?
Post #617139 21st Dec 2021 5:25pm
battery or loose connection to the battery? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #617141 21st Dec 2021 5:39pm
paddylimbo
We have checkesd the battery and the RAC man checked it a couple of times we he looked at it so don't believe it is that, we have had it off and on since fitting the ne module as well, and doble checked it.
Post #617149 21st Dec 2021 5:57pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I had this on my M62 4.4. I eventually wired a push start switch between the ignition switch to the starter motor. I still needed the key switched to position 2 but it started. I think there may be an issue with the wiring on some cars? This might help?
Regards
John
Post #617155 21st Dec 2021 6:53pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Another possible could be the gear selector inhibitor switch telling the ecu the car is in gear rather than park or neutral thereby preventing the starter motor operating. see thread here https://www.fullfatrr.com/forum/topic15665...r+selector
Post #617170 21st Dec 2021 8:01pm
tb10
@NobbyC: yes, good point but I changed my XYZ switch and it made no difference. The car did think it was stuck in 3rd but soon cleared when the ignition switch button was installed.
Post #617185 21st Dec 2021 9:50pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
Agree with potential inhibitor switch. I had that on a P38 years ago. You could try dropping it out of park and into neutral before cranking. L405 2017 TDV6 AB
Previous toys:
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Lots of Jags. Confirmed JLR nut.
Post #617186 21st Dec 2021 9:52pm
paddylimbo
Thanks Matt, tried it in neutral but no joy. so frustrating.
Post #617223 22nd Dec 2021 10:11am
Winkelried
Switzerland 2006 Range Rover Vogue 4.4 V8 Santorini Black
I've had this issue several times. Mostly its low voltage or a battery on its last legs.
Last week I had this after some fiddling around with the rovacom and searching for reasons of my suspension faults. Had some faults on the gearbox too and wasn't able to reset them.
Charged the battery, but nothing changed. So I disconnected the battery and let it sit over night. The next morning with a fully charged battery reconnected all was good again.
Except my suspension problems, but that's another story...
Post #618432 2nd Jan 2022 3:04pm
paddylimbo
thanks for that will have another try with the battery off.
Post #618684 4th Jan 2022 4:03pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I had exactly the same symptoms not that long ago, removed the xyz switch, cleaned out the inside and bent the wire pins so they were making better contact then put it all back together and haven't had a single problem with starting since.
Post #618695 4th Jan 2022 4:55pm
Gsxr1250dave
You can replace the ignition switch not do hard I did that on mine but it was the starter motor in the end.
You can also very easily strip the ignition switch down and clean the main contacts if they are burnt, an hours work start to finish and will illuminate that as a possible cause.
Post #618714 4th Jan 2022 6:22pm
