![]() | Home > Technical (L322) > M62 V8 4.4 help |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Once more, I am in need of the forum's ideas.
Thanks, I haven't boroscoped the cylinder but from what I could see the piston crown is just as black and sooty as the next one.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
is the left plug the right sort of plug, looks different to the right one to me RR 2005 4.4 petrol
Same type plug...The right type as per the manual.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
There's nothing wrong, just keep driving it |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
sounds like you had some leaked oil on the plug, from rocker gasket.. but with new plugs and coilpack, you eliminated all possible no5 misfire issue... you can have a coolant leak anywhere on this engine, they are known to have brittle gaskets, and weep a lot over time. just keep an eye on the guage, and level topped up, and you'll be fine. if its was the HG, it would be a lot more symptoms. and plug(s)
Thanks for this and yes, there was severe oil contamination on the old coil boots. I should have changed them all when I did the rocker cover gaskets. By the way I did a 500km trip today, in freezing conditions in the morning and rather warm at noon. It should have showed something...Did not face any issues though. Heater is also working well, almost unbearably warm at anything above the first red dot and 20C setting...
Well, I believe I have now exhausted all possibilities. It has to be the head gasket if not the block...Beyond any reasonable doubt, I mean.
let us know how you go RR 2005 4.4 petrol
Sure |
ok, so if you still have an overheating issue, then you must prove the thermostat is toast.... this could be the issue, and it might have cooked the head gasket, or, it might just still be the problem, without cooking the HG. so, search on here about upgrading the m62 thermostat, (which is cheaper than a Land Rover original,) and will regulate the temp better..(lower) and for about £50, you should be able to prove its not just a thermostat that's stuck open. you might want to watch a little overheating saga, on Youtube, with a guy that flips some half decent cars, and finds the faults, and MOSTLY fixes them etc. so here's a link to one of the episodes. you'll see his thermostat is drilled, you might want to replace it, or better still buy the modded kit, and fit etc. -unfortunatley, you can't remove it on the original, so 'Samcracc' (the YouTube guy) drills holes in his. |
Thanks for this, the thermostat is less than a year old and so is the water pump therefore I doubt they could be the culprit.
Fit a new cap (if you haven't already) bung some steel seal in, get it bled and topped up properly and drive it just keep an eye on the header tank level. Try not to drain or top up unless absolutely necessary.
Cap is new(ish), a few months old. I do seem to be getting combustion gases into the coolant, I need no tester to tell as the expansion tank stays pressurized overnight and smells awful when popped open.
