![]() | Home > Technical (L322) > Battery Drain Chasing |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
My alarm still keeps randomly going off and the other night it went off twice so I unlocked the car and left it unlocked.
More Data from the log
The battery is 3 months old.
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
Try disconnecting the bonnet switch and bridging the terminals in the connector. I had this issue and got fed up with getting up in the night to sort it.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
I would still charge and leave overnight ![]() Something is discharging it and it doesn’t appear to be the rest of the car. Best eliminate it. |
Yours must have a different type to mine as bonnet closed is open circuit and bonnet up is circuit closed on my car. I've simply disconnected the switch for now as that tells the car the bonnet is closed all the time. ![]() Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
I reckon it's an intermittent issue, I've got a 500 amp battery monitoring shunt on order so that will tell me (long term) if something is drawing down on the battery. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
Just a thought,
That's a very good point.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I don't think there is any singlepoint to do that as, AFAIK the alarm is interconnected with so many other things. Good advice to charge the battery up & disconnect it to see what happens - I had a new Varta battery fail in less than 3 months sio it could still be the battery. A tie wrap round the bonnet switch is as good a way as any to isolate it. |
Pjtaroni Member Since: 21 Aug 2021 Location: Loughborough Posts: 37 ![]() ![]() |
Have you checked for last alarm causes with a scanner? |
Rear doors both times, left and right. Christian.
razmachaz Member Since: 12 Nov 2021 Location: Brighton Posts: 2 ![]() ![]() ![]() |
I had the same issue. Rear doors apparently causing alarm to go off. Turned out to be the sun roof switch had been hit while cleaning and it was about 2mm down from sealed. Was causing the alarm about 15m after I locked or just left it open and it locked itself. Stopped doing it after I realised! |
