Home > Technical (L322) > Transmission Noise
suburbanspaceman
United Kingdom 2011 Range Rover Autobiography TDV8 Ipanema Sand
Transmission Noise
Hi All
Went for fuel this morning about a two mile run . Filled up, engine at just about normal temperature.Outside temperature about 2C . I went onto slip road to enter dual carriageway and accelerated hard. Noise from transmission ,passenger side of tunnel, it sounded like a cross between a thrust bearing on the way out and a stone trapped between brake dust guard and disc i.e. pretty awful !
I reduced speed and accelerated hard again up to 3K- 3.5K rpm. same noise but not as loud.
Carried on for about 8 miles at 70mph went off DC and then back on down slip road and accelerated, again in the same manner. No noise, tried again a couple of times - nothing.
It pulls well and smooth.
Any ideas - nothing indicated on GAP11. Could it be to gear box or transfer box fluids being too cold?
Anyone else experienced this?
Cheers
Post #617252 22nd Dec 2021 2:13pm
suburbanspaceman
Any ideas?
I’ve just driven 140 miles to Bath with no further noise.
Cheers and seasons greetings.
Post #617569 26th Dec 2021 11:22am
could have ben what you have suggested, a stone lodged between the disc and shield..
had you driven on a gravel track before the noise appeared maybe ? ... - .- -.
Post #617570 26th Dec 2021 11:26am
suburbanspaceman
Thanks for the reply Stan.
No Iwas meaning that’s what the sound reminded me of. Noise definitely came from beneath the passenger side of the tunnel and unfortunately I don’t have any dust guards. Hopefully it was a one off and temperature related. Time and miles will tell. In future I will make damn sure everything is warm before giving her any stick!
Cheers
Post #617575 26th Dec 2021 12:24pm
JayGee
I haven’t experienced this as going for full power after 2 miles from a cold winter start is to put it mildly Censored
Do yourself a favour and log the engine and gear oil temps with your GAP IID from a cold start. 2012 TDV8 Vogue (L322)
Post #617577 26th Dec 2021 1:17pm
suburbanspaceman
Thank for your wisdom JayGee
Post #617583 26th Dec 2021 1:59pm
