![]() | Home > Off Topic > Sheared torx key / Stuck in screw head? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1395 ![]() ![]() |
Do you have enough space to fit 2 nuts on the thread and lock them, then use a ring spanner to at least turn the bolt out several threads? Use penetrating oil etc to try and lube the screw thread that's in the pedal if you can. If you get some success you could continue on the fastener head with mole grips. When all else fails use a hammer |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8052 ![]() ![]() ![]() |
I know it will offend you Ryan, but I wouldn't even attempt to remove the bolt, just remove the sharp bit & live with it.
Slacken off / remove the other three bolts to give a bit of wiggle room and it should come out ok. |
Thanks for the replies chaps.
I think you need to lay off the porridge before tightening nuts and bolts in the future, they are only small diameter and shouldn’t need to be made ultra tight. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6816 ![]() ![]() ![]() |
I’m not sure you should concern yourself about marking it Ryan. Your size 10s will be all over it soon enough |
You’re quite right NDF, my fault. The OCD always gets the better of me |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I would hold the back nut, and use a reverse drill bit on the front and get it out that way. Should be pretty quick. Failing that, hammer a pointed tool into it and get it loose that way |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 156 ![]() ![]() |
Would a glue stick from a hot glue gun, melted to the broken bit end then let it wiggle out?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1843 ![]() ![]() |
Is the broken bit loose inside the bolt head?
Thanks for all the replies chaps which really helped with the way to go.
