![]() | Home > General > Tools to make life easier when working on the FF… |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Today I have been removing the fan and cowling in preparation of replacing my belt, pulleys, alternator, water pump and ac compressor.
The magnetic grabber is a good one… I don’t have one and have been fortunate to not need it. But can see it’s usefulness so will add one to my arsenal of tools!
This is what I have…
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
The magnetic tool is a life saver. I use mine next to that nut or bolt that you can't get both hands on so if it drops out your fingers or socket it catches the nut or bolt from dropping never to be seen again. It's very useful recovering something that's dropped down into the bottom engine cover. I once dropped just one bolt and retrieved 2 more along with a small spanner. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I wouldn’t be without my trusty Milwaukee compact impact wrench. So small, so powerful, and has not let me down yet to undo anything.
![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Agreed! And pair it to one of these to keep the alloys in good nic…
Oh that looks interesting. I must resist, too many impact sockets as it is 🤣
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
And if all else fails always have a fall back plan :-
Seriously though folks I have the following Laser tools and have used the 5978 for the upper bushes, still have the lower ones to do:-
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
just got a pair of rear upper bushes through the post, so got that job at the weekend... I bought a cheaper set of removal tools, on their way, but handle the 45mm upper bush, at just £24 set.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Thanks for the 'heads up!' pun intended! ![]() Ordered a pair of them ![]() ![]() ![]() |
I only use my impact driver on wheels as I’m lazy! I zip round to take them off… and on my guns lowest setting to put them back. It still needs a few turns of the torque wrench to get them to the right tightness. Like many, I’ve been stuck on the side of a road with a puncture fighting with over tightened wheel nuts! In my younger days I put in a wheel nut with a gun and mis-threaded it. Luckily an experienced mechanic had the tools and know how to remove and re-thread the hole. As a result I am extra careful putting them in and tightening. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Love it ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
