![]() | Home > Technical (L322) > 2010 3.6 TDV8 FBH Problem |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
Just had a reply from a friend who works for an LR dealer........ It is 13.
I left the fuse out for about 20 minutes then put it back in and tried the test in the IID again.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
How about:
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Also make sure your battery is fully charged as if it detects insufficient power it stops to keep enough to crank the engine from memory |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
You may have tried this, but ISTR somewhere on here that doing a hard battery reset can resolve the problem.
Thank-you all!
I think the E7 is a generic GAP code, I've seen mention of it with other tests on Disco 3s. That second link is quite interesting..... especially "The fuse must be removed with the engine running or within 60 seconds after the engine has been shut down". I haven't seen mention of the within 60 seconds before so will give it a try again tomorrow, thanks!
Thanks, unfortunately I don't know the history of the battery (It was only a couple of weeks ago that I picked up the car) so will dig out a meter when it's daylight.
I haven't seen any evidence of the FBH starting at all, at any temperature. If the temp is cold enough tomorrow I'll stick my head under the LH wheelarch & try the remote (after the fuse-reset within 60 seconds of the engine being shut down). If there's no luck I'll try the battery reset. Thanks! Richard 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
Now that I think about it:
Good question........ I'll give that a go in the morning & then have a look for fault codes.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
No fault codes come up under FBH in IID?
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1014 ![]() ![]() |
With the gap tool just do a vehicle reset that will clear any lock out the fbh has stored in it, they will lock out after x3 failed attempts to run be it from low fuel to other reasons. |
Nope, no FBH related faults. I needed to go somewhere this evening & remembered that the 753 menu show battery voltage; 11.5....... that was with ignition on but engine not running. Is 11.5 low enough to prevent the FBH firing?
Ah, I knew about the reset function but not that it would clear FBH lockouts. Do you happen to know what else it resets / clears? Cheers Richard 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
11.5 is low. I would check FBH live data. |
Just been out to the car with a meter.
