Home > Technical (L322) > fuel |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
would larger tires help with the fuel mpg RR 2005 4.4 petrol
18th Dec 2021 4:17pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2711 |
Run your tyres at the highest safe pressure to reduce rolling resistance . A larger wheel circumference ( bigger tyres) will effectively mean taller gearing but depending on where the torque band is in the engine it may or may not result in better MPG. Biggest difference will come from how you drive i.e lower you speed on the highway and accelerate as slowly as possible to get up to speed. Also drive with maximum anticipation of the road ahead to avoid using brakes + accelerator ( brakes turn momentum into wasted heat which needs replenishing with burning fuel). 2012 TDV8 Vogue (L322) |
18th Dec 2021 4:48pm |
thanks for your comments
19th Dec 2021 2:37am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 696 |
It’s always worth checking the brake callipers aren’t seized, the rears are particularly prone to doing it without any obvious symptoms. |
19th Dec 2021 4:41am |
thats a thought
19th Dec 2021 5:43am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Assuming everything is mechanically is correct, then the big impact is driving style. Easy smooth driving does it every time. |
19th Dec 2021 7:19am |
trew RR 2005 4.4 petrol
19th Dec 2021 7:39am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
M62 is one of the best ever candidates for an lpg conversion - I had two in BMWs and one in my l322 ran great Current stable:
21st Dec 2021 3:19pm |
Thinking about tires, my RR is fitted with 275/45R20, which is smaller in diameter than the original 255/55R20,
2nd Jan 2022 8:08am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
Does your car have an EGR system?
2nd Jan 2022 8:36am |
Also, if your tyres are incorrectly sized, then ignore the on board mpg readings.
2nd Jan 2022 8:40am |
yes thats a thought, thanks RR 2005 4.4 petrol
2nd Jan 2022 9:06am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Are you running on the 275 60`s? if so do they fit ok. I was lucky to pick up a set of 5 275 55 20 Bridgestone's at A$20 each brand new, I am still waiting for my current tyres to wear down to warrant changing them. Currently on 275 50 '20s. 2007 TDV8 VSE
2nd Jan 2022 10:56am |
No, I only picked them up to day
2nd Jan 2022 12:58pm |
