|  | Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox? |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | Happy New Year!
|  1st Jan 2022 1:41pm |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | Thanks Phil for sharing your wisdom regarding the ATF. Learned now that i did something right for the wrong reason  | ||
|  1st Jan 2022 3:36pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | I’m not sure if it might be worth trying the BMW forums in the search of more information, as the same transmission (BMW call it the A5S360R/A5S390R) was used in E53 (X5), E83 (X3), E46 (3-series) & E39 (5-series).
|  2nd Jan 2022 8:31pm |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | Thnak you again Phil  | ||
|  3rd Jan 2022 4:12pm |
| madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137      | hi, I can tell you with certainty, that the springs of the accumulators, for l322 are not the same they are of different sizes, also specifies it on the sonnax website, I am updating the valve group with sonnax, and I must say that the new pistons operated by the soleinoids , they are made really well, when the gearbox is about to yield, you realize, in part at the minimum that there is something crawling, such as finished brake pads. | ||
|  4th Jan 2022 9:20am |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | Hello Madcima, thanks for your clear statement that these accumulator springs should be of different sizes. That should mean that for my valve body it all could be as it should be. I couldn't find anything of documentation or website info on this. You say it is on the Sonnax website but I am not able to find it. Do you have a link to this info?
|  4th Jan 2022 9:42am |
| madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137      | https://www.sonnax.com/tech_resources/295-...tification here is the link, i'm in emilia romagna | ||
|  4th Jan 2022 10:40am |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | Thanks madcima!  | ||
|  4th Jan 2022 1:27pm |
| madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137      | wait, I fixed it on my own, I am not a repair shop! I can tell you that the springs are of two types of length, 2 long and 2 short at least in mine it was like this, instead the repair manual says that they are all 4 the same.
|  4th Jan 2022 1:34pm |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | O wow, that's high tech! Well done  | ||
|  4th Jan 2022 1:46pm |
| madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137      | I would like to post photos but it won't let me do it | ||
|  4th Jan 2022 1:49pm |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169      | first hit button "choose Photos" just on the left side under the text box. After that you can click on the "upload" button on the right side. After that you have to click on the uploaded photo to insert into your text box. That way it should do it. | ||
|  4th Jan 2022 2:50pm |
|  4th Jan 2022 3:16pm |
|  4th Jan 2022 3:22pm |
| Posting Rules
 and yes, the same problems again (some weeks ago even 10 minutes idle before able to move
  and yes, the same problems again (some weeks ago even 10 minutes idle before able to move  This last year I also experienced a very light fluctuation in revs (50-100) when doing around 70 KM/H and also my MPG seemd to decline a bit. So really time for some action!
 checked line pressure withe a gauge: 50 PSI at idle in P and N, 140 PSI at 1000RPM in R (brakes applied), 120 PSI at 1000 RPM in D (brakes applied) and revving up in P and N to 1500 to 2000 RPM resulted in 60-70 PSI. Was a bit disappointed with the 50 PSI as it is like the minimum... Are these figures okay or do I need to worry about it?
 Then I checked all the accumulators. Really confused about what I found out. In a GM 5L40E repair manual it is stated that all four springs should be the same. I found three different sizes with mine
 Have to do that on the next ATF change in the next weeks.
