Home > Technical (L322) > New Battery = Hot seat
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
Last year my drivers heated seat stopped working. I would push the heat button and it would come on for around 10 seconds and then switch itself off. I checked fuses, connections and carried out some continuity testing but couldn’t find a fault.
Last winter I jumped into Sylvia, turned the key and was greeted with a resounding “clonk”. A quick jump start, clear any codes thrown up and I was back on the road. Last week I twice went to start up only to find that the battery was dead.
On Sunday I bit the bullet and bought a new battery. Fitted without incident and Sylvia a happy Rangy once again. Yesterday I inadvertently pushed the drivers heated seat button only for it to come on and heat up without issue. I think that because I disconnected the battery everything on the car reset? I didn’t do a hard reset by touching the positive and negative battery leads together but there was a 10 minute period where there was no battery on the car.
If you are having problems with your heated seat I would try disconnecting and reconnecting your battery before you spend hours looking for broken wires etc.
Jim
Post #618643 4th Jan 2022 10:37am
it appears nowadays that most things like phones, PC's and now cars have to have a 'reboot' to settle problematic electronics..
glad its all sorted Jim.. Thumbs Up ... - .- -.
Post #618647 4th Jan 2022 11:04am
Or is the seat ECU clever enough to know that the failing battery drops the current to a dangerous level so switches the seat heater off...!!
Did the passenger one work OK..??
What about the heated steering wheel..?
Thumbs Up Pete
-Click here for Thread-
Post #618655 4th Jan 2022 12:29pm
jim4244
Heated steering wheel and passenger seat worked fine so not really sure what was reset when I put the new battery on?
Jim
Post #618670 4th Jan 2022 2:13pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
A Fattie seems to be like everything else with a computer, when in doubt, pull the plug out, amazing the problems that solves.
Post #618674 4th Jan 2022 2:40pm
