![]() | Home > My Range Rover > Maybe not everyones taste but its mine.............. |
| Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234
My FFRR with 22" Stormers - i know there will be a lot of umming and arghing regarding 22s on a FFRR but i think they fill out the arches nicely.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
many FFRR owners have 19'' on theirs because of the ride and they look ok when in access mode, i personally think that 20'' is the minimum size as when you stick the range into standard the 19'' dont look right...your 22' will look even better in standard mode and they do suit yours well...hows the ride btw? ... - .- -.
Scarey - i went from 19" standards to 20" with 45 profile and now 22" with even lower profile and to be honest i dont get any vibrations , sure the ride is not as soft as on the 19" but i dont really notice any major changes. CURRENT : FFRR 2012 4.4 TDV8
do you get the vibes at the traffic lights when still in 'drive' or do you do what i do and put it into neutral... ... - .- -.
No vibration noticable! either my suspension is on its way out or i have a super padded ar#s! CURRENT : FFRR 2012 4.4 TDV8
same as the 20'', 34 and 36...yes 45 is way to much.. ... - .- -.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
My 20"s are 42 rear 36 fronts .... |
thats cos you need to loose some weight mick..... |
Note to self , when driving leave wallet in house ..... |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
scarery im sure i read somewhere that the juddering when staitionary means you need to change the fluid in your gearbox....
had a new gearbox in january 2010 so i'm hoping thats not the case.... |
