Home > Technical (L322) > MAF Sensor Wiring Fault
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Using IID Tool I noticed the other day and I noticed that the reading from the MAF sensor on one bank was showing 0 volts. I swapped the sensors over and the fault remained on the same side. I'm assuming I must have a wiring fault (L322 TDV8 '11) but I'm unsure where to look.
Any and all suggestions welcome. Thanks.
Post #618745 4th Jan 2022 9:32pm
kevinp
I could be wrong Mike but could that MAF sensor only start working when the secondary turbo fires up?
Post #618748 4th Jan 2022 9:42pm
Mike Edwards
Ah, good point. I will have to drive it a bit harder and see what happens. I've had so many small wiring faults recently I just put 2 & 2 together and made 5.
Post #618749 4th Jan 2022 9:48pm
JayGee
The would be a fault showing on your IID code scan if a sensor was not functioning or out of a normal range. 2012 TDV8 Vogue (L322)
Post #618759 4th Jan 2022 10:39pm
Mike Edwards
I first started looking in this area due to a message, such as:
"P0105-16 (6Cool Manifold absolute pressure/barometric Circuit - General electrical failure - circuit voltage was below threshold"
I suspect a one off issue then led me to spend too much time looking at the 0 volts output from the MAF sensor which was a distraction.
Post #618763 4th Jan 2022 11:14pm
JayGee
AFAIK there is just one MAP ( pressure sensor) which is on top of the plenum. There are MAF sensors on each intake airbox and an intake air temp sensor just before the throttle body. Only today on mine I noticed how hard the insulation was on the MAF sensor wires and how they were not covered so quite easy to imagine an internal breakage. Also worth pulling out the MAP sensor to check for soot fouling as this could cause a faulty reading. 2012 TDV8 Vogue (L322)
Post #618769 4th Jan 2022 11:51pm
DrRob
Yes, MAP is a single sensor in the plenum. Your error code hints to that but I'd first check it against the myriad of codes that are explained in the workshop manual (free in the Wiki). Just checked and it's in there under "Engine Control Module" in the "Diagnostic Trouble Codes" folder.
Easy to remove. Unclip wires, Torx25 and it pops out. I do it every oil change (6 months) and blast with brake cleaner. It's always a bit furry. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #618796 5th Jan 2022 8:55am
