Home > Maintenance & Mods (L322) > Mot fail
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Mot fail
Well that's a kick in the face but that's life I guess. Now time too get the easier jobs done and get the garage too do the welding. Think I can safely say the previous mot was a bent one as even the tester questioned how it past last year with out a single issue and this is the list for this year.
So where would you go to get this list of parts except for the arches and welding
Post #618890 5th Jan 2022 6:38pm
That's not good, I'd get quotes for the welding before anything else, make sure it's worthwhile, to do it properly is an awful lot of work...... Big Cry Pete
Post #618896 5th Jan 2022 7:14pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
I would agree with Haylands - get a quote for the welding before you do anything else.
Post #618898 5th Jan 2022 7:31pm
Bean19844
Pete
I'm going to get it done as I plan on keeping this one as it does everything I need and saves me having too keep a transit van that's capable of pulling 3.5ton behind me. Garage I used for the other range rover have already said they will do the work. Unfortunately I just don't have the money this month so will be going in for the welding work around the 24th January so figured well now I've got some time, I might as well get the arms done, possibly the front arms and the brakes done.
Everything I've seen online, it would appear that it's a drive shaft removal job so figured if I can order the parts tomorrow, hopefully if it turns up for Friday I can start on it Saturday
Looks like I'll be on this for time being
Post #618899 5th Jan 2022 7:33pm
Bean19844
One thing that bugs me is this. What's peoples opinions on using these parts. Going by the top one given 411 people have bought these, are they recommended or just an easy "pass an mot" setup.
I know delphi have a good reputation so I'd prob go for these if I wasn't too go for land rover parts.
Any thoughts folks
Post #618901 5th Jan 2022 7:39pm
Gsxr1250dave
Every cloud has a silver lining urs is B king
Post #618905 5th Jan 2022 8:29pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
At these prices I just look at them as a service item. I reckon that they are probably all made in the same factory anyhow. L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #618906 5th Jan 2022 8:29pm
Bean19844
Gsxr dave
Yea it's a b king. Decent bike plenty of power that's for sure
Richm63
Tbh I've never been a fab of replacing parts that will need doing again in a year or so. I'd rather the job done properly but I'll always look around at least at aftermarket parts
Post #618907 5th Jan 2022 8:34pm
Delphi should be OK they are an OEM for Land Rover...
The only problem you have is ensuring they are genuine and not fake parts, if the seller has a good lengthy feedback I suppose they will be OK..
Don't buy made brake pipes, use nickel-copper alloy pipes and make your own... Thumbs Up Pete
Post #618913 5th Jan 2022 9:16pm
Bean19844
Pete
Would you trust any of the sites such as lr trade parts, island 4×4, British parts etc.
I've seen some of their stuff and it seems too come in pretty cheap. Almost too cheap for my liking
Post #618919 5th Jan 2022 10:38pm
dhallworth
Yikes, is that your 4.2?
I’ve got the itch for another car again and I keep looking at 5.0’s but with the amount of corrosion that’s starting to bite on the L322’s I’m reluctant to do anything unless it’s a car I can go over with a tooth comb first.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #618921 5th Jan 2022 10:53pm
Bean19844
David
Yes it is sadly. Its a lot more work then it appears as everything is doubled up. I'm just debating on do I do a complete suspension rebuild so both front arms and the ball joints or do I just replace what's actually needed.
I'm not too worried about the welding as these guys are pretty good with it when they done my other one but ideally I'd like too get all these parts fitted before hand so it's less labour too fork out. They've already said genuine land rover arms with fitting I'm looking at around £350 per arm so I'm thinking of just getting the delphi arm kit, new bolts, nuts for around £250 and do it all myself.
So including brake pads being Ferrados it's a total of just over £300 for the whole lot. If I take the other option and only replace what's needed then I'm looking at around the £200 as I'll replace the nuts and bolts all round
Allen
Post #618923 5th Jan 2022 11:22pm
dhallworth
If you’re thinking of keeping it for the long term then I guess doing both sides makes sense as it’ll likely not need doing again.
You’d only need to get the alignment checked once afterwards too.
Post #618927 6th Jan 2022 12:03am
Danwilderspin
The rear corrosion is it jus the rear subframe? If so can you get a used one form a newer car? This is a real weak point in these I looked at a good 5 or 6 of similar ages before I found my 07 most of them looked like they’d been parked in salt water with dodgy mots Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #618931 6th Jan 2022 12:49am
Am i missing something? It states its a RRS on the MOT failure... Whistle
Post #618934 6th Jan 2022 12:57am
