Home > Technical (L322) > Heater fan not working
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Well it had to happen almost exactly one year of trouble free ownership and after sitting for 10 days due to me isolating I get in the car today and it was cold even though I’d pressed the pre heat that I heard start up, driving along I notice we’re steaming up the bloody fan doesn’t work on any settings the rear one is ok and there are two fault codes, I’m hoping it has nothing to do with the screen being replaced before Christmas, any ideas I’m going to look at fuses etc once I’ve defrosted 😂
 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #618805 5th Jan 2022 10:02am
Furnitureman
And to top it off for the life of me I can’t find the fuse mentioned in the hand book for the front blower motor can someone tell me where it is pleasev 2012 Range Rover Westminster 4.4 TDV8
Post #618808 5th Jan 2022 10:16am
Furnitureman
Anyone able to help I’m stuck with this one 2012 Range Rover Westminster 4.4 TDV8
Post #618946 6th Jan 2022 10:28am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I can only speak of earlier cars however it's possibly the same on the 2010/2012 cars. The final stage resistor can cause the fan to act erratically including not at all. See the video in the link, ignore the left side steering wheel, its in the same place for the RHD.  2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #618947 6th Jan 2022 10:37am
DrRob
Mine stopped working once and then started working again. Odd eh?
See if it improves over next few days. I've seen those codes on mine but clear them Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #618953 6th Jan 2022 11:48am
mpirie
My advice would be to make sure you exhaust every alternative before undertaking fan replacement.
Check the fuses, try some electrical cleaner on the motor (involves removing the cabin air filter box etc) then the fsr.
Fan replacement involves removing much of the upper dash. The replacement fan isn't expensive, but the time it take to replace would e at a dealers.
Mike
Post #618957 6th Jan 2022 12:04pm
Furnitureman
Thanks for the replies, unfortunately its not great news, on the 2012 there is no mention in the handbook or any of the fuse boards for the front blower fan fuse or relay which is dammed annoying i pulled all the fuses for the rear and everything is ok, so i got a new genuine FSR and swapped it, and still nothing Censored Censored Censored im now looking at replacing the fan but before i do can anyone confirm how easily the fan spins by hand on a known working model, or anything else i need to look for before stripping out the dash 2012 Range Rover Westminster 4.4 TDV8
Post #619133 7th Jan 2022 6:38pm
If I’m not mistaken the front fuse board for 2002 to 2012 cars are the same ( ? ) in which case you need to look at Fuse 34 7.5A. It’s marked Airconditioning, Blower. Front windscreen.
As l don’t have a 2012 car l may be mistaken but definitely worth a look.
The blower fan will definitely have a fuse. Thumbs Up
Post #619134 7th Jan 2022 6:55pm
mjdronfield
Fuse 64 somewhere then…..
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #619135 7th Jan 2022 7:28pm
Furnitureman
Fuse 34 in my car has a symbol for the petrol / diesel pump so im assuming its the filler cap fuse
Thanks for the info though 2012 Range Rover Westminster 4.4 TDV8
Post #619139 7th Jan 2022 8:59pm
Furnitureman
picture is my dash but fuse 64 in the cjb which im assuming s the one in the dash is in my car is for dvd which is there but u dont have a dvd but when i did a search online for 2012 fuse box i get this image that clearly shows fuse 64 but i dont have this fuse board
im bloody confused as i cant find any reference to a fuse in any of the three locations for the front blower and there must be one 2012 Range Rover Westminster 4.4 TDV8
Post #619140 7th Jan 2022 9:06pm
To simplify matters just check every 5A and 7.5A fuse on the front fuse board, there aren’t that many.
Post #619142 7th Jan 2022 9:15pm
Furnitureman
ill give it a go thank you 2012 Range Rover Westminster 4.4 TDV8
Post #619143 7th Jan 2022 9:22pm
Furnitureman
Puller them and all good 2012 Range Rover Westminster 4.4 TDV8
Post #619145 7th Jan 2022 9:50pm
mjdronfield
That’s a pain then. The screenshots were from the 2010 2012 Workshop Manual….
No idea….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #619147 7th Jan 2022 10:02pm
