Home > Technical (L322) > The dreaded adaptive dynamics fault
BINDERMINDER
United States 2011 Range Rover Supercharged 5.0 SC V8 Santorini Black
I have just got the adaptive dynamic fault. I have inspected the leads on all 4 shocks, they all look ok. As my old scanner did little as far as diagnostics, I purchased the Icarsoft LR V3 to attempt to narrow the problem to one corner. The scanner only gives me code "C1B14-1C" "PERMANENT SENSOR SUPPLY 1". Does anyone have a clue where I should look with this information??
Post #619030 6th Jan 2022 8:12pm
BINDERMINDER
Sorry, This is in reference to my 2011 RR L322 with 5.0 SC
Post #619031 6th Jan 2022 8:13pm
DrRob
In the workshop manual there's a file called diagnostic codes to look up codes. Download from Wiki (scroll to bottom of the page) 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #619034 6th Jan 2022 8:25pm
BINDERMINDER
Thanks Dr. Rob! It appears to be a code for power supply for the lower accelerometer or transducer. Wonderful... Now can anyone with more knowledge than I tell me where to go from here?
Post #619039 6th Jan 2022 8:42pm
DrRob
Good but can't help you anymore as knowledge is zero on that topic Crying or Very sad 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #619049 6th Jan 2022 9:33pm
JayGee
The system uses 3 accelerometers. The easy one to access is on the right rear side of the spare wheel well and is also the easiest to damage so start there. I think the others are hidden behind body panels. 2012 TDV8 Vogue (L322)
Post #619053 6th Jan 2022 10:09pm
rjff
Binder
Have you had the spare wheel out or jacked up the car to get a wheel of the ground?
I ask because the code you give is showing in the WM (link)
https://drive.google.com/file/d/0Byv5LFgQZ...yXSlJt_k7A
as C1B14-1C
is for height sensors
the next one C1B15-1C is for accelerometers.
If you haven't done either then it is quite possible it is the front damper wiring. It does sometimes appear to be OK but my be broken inside the sheath giving a fault.
I may be well out but HTH. Cheers
Richard
Gap IIDBT
Post #619054 6th Jan 2022 10:51pm
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi. I fitted two new solenoids and soldered the wires. No problem since. They're cheap Smile Ken ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #619055 6th Jan 2022 11:40pm
BINDERMINDER
As I've just purchased this "big brother" to my '11 Jag XKR back in October, I haven't done anything but change the oil and the wipers. I've had some time today to read as much literature as possible on this issue (and many others) Smile my fullfat folder is growing quite large and I will be using this new found knowledge for the CD player, the front cigar lighter receptacles and the rear entertainment quirks. From what I have found, C1B14-1c relates to Sensor supply 1
Lower lateral accelerometer or pressure transducer supply circuit: short circuit to other circuit or ground.
Lower lateral accelerometer fault
Pressure transducer fault
Post #619061 7th Jan 2022 12:36am
BINDERMINDER
One other thing, the air will go out of the front shocks overnight. This was ocurring before the AD fault.
I will be checking for leaks.
Post #619062 7th Jan 2022 12:40am
BINDERMINDER
So.. my mistake! The definition 0f DTC c1b14-1c that I had read over earlier pertaining to the accelerometer was from a 2006 RRdocument. RJFF directed me to the google docs RRWM from 2014 and it says this DTC is for the height sensors. I won't ask why... but why??? Thanks for the insight. Anyone with knowledge of best methods for testing will be my next best friend! Cool
Post #619070 7th Jan 2022 6:07am
JayGee
rjff wrote:
Binder
as C1B14-1C
Thanks for the link - that's a world of useful info! 2012 TDV8 Vogue (L322)
Post #619125 7th Jan 2022 4:46pm
