Home > Technical (L322) > Help needed - 4.4. TDV8 fuel pressure too high |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2970 |
I've no idea what the setup on the 4.4 TDV8 is so I'm only thinking aloud here.
10th Jan 2022 4:44pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
The fuel cooler cools returned fuel. There is a valve in the lines just after the cooler that links to the inline fuel pump. The valve is part of that section of fuel line LR031822 which superseded an earlier version at vin BA352847. Perhaps that valve is faulty with increasing possibility if your vin is before BA352847. |
10th Jan 2022 9:08pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 304 |
I had all injectors out of my 2012 and tested by a Bosch diesel specialist, they were all pristine.
12th Jan 2022 1:08am |
maxg67 Member Since: 10 Jan 2020 Location: Verbania Posts: 12 |
I had them tested and refurbished just 5000 km ago, but then the H.P. pump broke again.
12th Jan 2022 11:46am |
That fuel pressure quoted in the manual will be across certain conditions such as idling, light load, full load, wide open throttle, etc.
12th Jan 2022 12:08pm |
Is the HPFP meant to be timed? The pump on the 2.7 TDV6 isn't timed but it is on the 3.0 TDV6/SDV6 and the 4.4 is of the same generation as the 3.0 so might be. I don't have that section of the WSM but hopefully the mechanic doing the work does so probably not the cause. |
12th Jan 2022 8:52pm |
See this current post which points to LTB01083, being a faulty electrical connection repair.
13th Jan 2022 9:09pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Is this a common issue? lookslike the parts been superseded to LR112662 SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
14th Jan 2022 7:44pm |
LR112662 is listed only for the L405/L494 by various sites but that could easily be due to a failure to list also for the L322. Regardless, it does appear to be common enough to remember the issue to avoid expensive repairs that don't solve the problem.
14th Jan 2022 8:54pm |
Cool, the connector might be the issue then? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
14th Jan 2022 10:18pm |
The TSB is to replace the connector on the engine harness but maybe both halves have been improved. Maybe cut them both off and replace with Deutsch connectors. |
14th Jan 2022 10:44pm |
Finally solved.
25th Feb 2022 2:37pm |
