Home > Technical (L322) > Trans fail safe |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
A faulty transfer box shift motor potentiometer is a possible cause (although, usually, it's the battery). Does the transfer box shift into low range and then back into high range okay?
12th Jan 2022 12:18am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
When you say "the batteries good" how have you checked sir? |
12th Jan 2022 1:25am |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 527 |
Phil & Craig are right about the battery.
12th Jan 2022 8:08am |
Jimes256 Member Since: 14 Mar 2021 Location: Bath Posts: 34 |
Battery is new and I’ve charged it to make sure. Not sure about lights on dash. Wonder what happens to potentiometer..... |
12th Jan 2022 10:20pm |
I wonder what goes on the potentiometer to only effect it when cold? Put the inhibitor back on and still the same. No display on dash. |
13th Jan 2022 9:26pm |
