Home > Off Topic > Sprinter Jack lost it's mojo
GGDR
went to use my sprinter jack today after nearly a year of non-use and it was going down half as much as I was pumping up. Valve was locked closed hard hard and then I noticed some oil coming ou from around the main piston.
I got it up enough for the second piston to come up but I could not get the wheel off the ground.
Presumably I need oil and o-rings?
Any tips would be appreciated.
Bow down
. Cheers, Greg
Post #619798 13th Jan 2022 12:13pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I'd just buy a new bottle jack from SGS. They're cheaper than people want for a second hand merc one.
Not sure its advisable to disassemble a lifting device. Risk is just too great IMO. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #619807 13th Jan 2022 1:23pm
Caesium
https://www.sgs-engineering.com/9005a-5-ton-hydraulic-bottle-jack
LIFETIME!(!) Warranty. £75. Bargain. Christian.
Current Cars
2019 BMW X4
or
Post #619808 13th Jan 2022 1:25pm
GGDR
thanks but I don't think that has enough lift. Sprinter jacks have a two section piston
. Cheers, Greg
Post #619812 13th Jan 2022 2:10pm
Caesium
Try this one
https://www.sgs-engineering.com/tbj4-4-ton-telescopic-bottle-jack Christian.
Current Cars
2019 BMW X4
or
Post #619814 13th Jan 2022 2:15pm
Baltic Blue
Sorry Greg, this contribution is not much help, but talking of seals , I saw over 100 of them basking on the beach as I walked around Great Orme this morning Rolling with laughter
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #619832 13th Jan 2022 4:47pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Mike,
A word of caution..........
Watch out for low flying sprinter bottle jacks !
Ian Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #619834 13th Jan 2022 5:36pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Greg
maybe this will help
https://www.wikihow.com/Add-Oil-to-a-Hydraulic-Jack
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #619837 13th Jan 2022 5:43pm
Baltic Blue
Ian,
I hope his Aussie sense of humour takes pity on me.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #619844 13th Jan 2022 6:13pm
GGDR
Wide berthing the yokes Shocked
. Cheers, Greg
Post #619945 14th Jan 2022 12:30pm
GGDR
So I tried it again today after watching a few YouTubes
I gave it an "air bleed" and it seems better but I suspect it's low on fluid as it won't extend fully. But it is now holding load and not slowly dropping.
I have ordered some bottle jack fluid so I will do a fluid change, re-bleed it and see how it goes.
It didn't leak today either and I just and I mean just got the car high enough to get the wheel off. Axle stands went immediately underneath too.
Mine like many has had a aluminium block fitted which works a bloody treat so I would rather get this one running since I spent a good few hours fabricating the ally block.
Or get a replacement Sprinter. Cheers, Greg
Post #619946 14th Jan 2022 12:35pm
I've got the opposite problem with mine - it won't stay fully home and starts to rise all by itself Whistle
And it also leaks oil Got - 2017 SDV8 Autobiography in Loire Blue
Post #619947 14th Jan 2022 12:40pm
