Home > Maintenance & Mods (L322) > Range rover wheel nuts
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Afternoon all
You'll have too forgive me on this one but anyone know how you remove these wheel nut covers. They feel like they are on pretty tight if I'm honest but I can't even seem too find the correct size socket too get them off
Any suggestions please folks
Allen
Post #620064 15th Jan 2022 4:53pm
Discotigger
Sounds like you have swollen nuts! The nuts should take a 22mm socket, but if they swell up then it wont fit. You will have to remove them with an impact socket hammered onto the nut. They will need replacing IMHO, plenty of threads on this forum about this problem.
Post #620065 15th Jan 2022 5:11pm
JCW
Should be a 22mm socket but if they’re slightly swollen from corrosion under the stainless ‘cover’ you may need to use a 23mm instead
Post #620066 15th Jan 2022 5:12pm
Bean19844
So the stainless steel ain't a cover then I take it and just needs an impact socket forced on to it.
Where's a good place too get some new wheel nuts that preferably won't have this issue of swollen nuts
Post #620069 15th Jan 2022 5:22pm
Discotigger
The nuts are steel with a stainless steel cover fixed to them. The steel nuts will swell over time and this causes the covers to deform as well. If you can get your hands on a 23mm socket, that should fit, however the nuts ideally need replacing. There's plenty on ebay, the best ones to get are full stainless steel nuts, but they're expensive.
I got a good set of alloy ones which should be okay for a good long time.
As mentioned, check some of the other threads on this forum, it will help you decide which replacement nuts to get Thumbs Up
Post #620074 15th Jan 2022 5:32pm
Bean19844
Cheers pal
I've gotta go to halfrauds as I need a 21mm spanner so I'll just grab a 22 and 23mm socket while I'm in there.
I'm not too worried about replacing them just yet as the car don't have any mot so while the welding is being done I'll get these ordered but I need too get the brakes and the arms replaced first off
Post #620079 15th Jan 2022 5:42pm
kevinp
I had the same trouble but you will find a 12 point 21mm socket will work.
Post #620081 15th Jan 2022 5:46pm
Bean19844
Cheers Kevin
I've picked up the sockets and spanner so hopefully will all go OK tomorrow
Post #620108 15th Jan 2022 8:25pm
mjdronfield
I got these from the bay of e….
Happy so far…
Got a few spares as I have locking wheel nuts, so not used them all…
https://www.ebay.co.uk/itm/201565501081
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #620109 15th Jan 2022 8:41pm
Fox889
Bean: I replaced mine 2 years ago and have the old ones (with locking nuts) sitting in the garage doing sweet fa!
I replaced them for no reason other than the new ones were….errr….new! Cover the postage & they’re yours if you want them? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #620134 16th Jan 2022 9:23am
JayGee
Wheel nut / bolt maintenance should be part of the service schedule. Remove, clean up any rust on the threads (do not add grease) check and clean wheel to hub mating surfaces, torque the nuts to correct settings. Makes life a lot easier when you get a puncture. 2012 TDV8 Vogue (L322)
Post #620138 16th Jan 2022 10:11am
In over 25 years of owning LR vehicles with these particular wheel nuts l have only once experienced a swollen nut. I put this down to the fact that once a year l tend to liberally drip engine oil into the gap between the wheel nut and its cover, usually when the wheels are off for routine maintenance.
It seems to work. Thumbs Up
Post #620139 16th Jan 2022 10:14am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
22mm as above
I use 7/8 inch socket to remove swollen ones
Post #620140 16th Jan 2022 10:30am
Bean19844
Cheers chaps. 23mm socket done the job but I'll be getting some new nuts.
Foxy you'll have a pm in a few mins
Post #620205 16th Jan 2022 5:28pm
mjdronfield
Yes, if they swell too much you won’t get any socket on without damaging the alloy…. Then its hammer and chisel time….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #620213 16th Jan 2022 6:15pm
