![]() | Home > Technical (L322) > Wonky fuel guage ................ |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
A bit more info is required please |
ex bm Member Since: 10 Jun 2009 Location: uk Posts: 6 ![]() |
left the car overnight hoping that it would somehow fix itself !!! - but no.
Ivan Member Since: 12 Apr 2009 Location: N. Ireland Posts: 44 ![]() ![]() ![]() |
Mine ('05 S/C) does this too, usually worse after filling up. My MSV tells me "Fuel Sender 2 Circuit , General Electrical Failure, Circuit short to battery or open (intermittent)" When I get time I'll look at the connector on top of the sender unit, until then use the trip and put in lots of petrol!
I have the car booked in for monday to have it checked out but I want to check the connections to the sender unit myself this weekend just incase its a dodgy connection.
If you do a search BBS Spy did a write-up on replacing his fuel pump, this should point you in the right direction. I'll be interested to hear your results,
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Monitoring this thread as I have a wonky guage too. Mine reads quarter full and then runs out of fuel. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
It must be a Landrover trait. My SIII used to do this. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
You may find this interesting reading:
