![]() | Home > Technical (L322) > Handbrake MOT Failure |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Stop on a steep hill. Shift into neutral and apply parking brake. If the car holds then parking brake is fine. |
If you are worried about your handbrake operation it would be worth taking off the rear drum/ discs and cleaning out all the crud that collects in there. The crud tends to act as lubrication between the shoes and the drum greatly reducing the handbrakes efficiency. While you are in there it is also worth emery papering the surface of the shoes to remove any glazing. |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 252 ![]() ![]() ![]() |
I'm not worried about the operation, I just need it to work long enough to pass the MOT. Or at least have the MOT place assure me they tested it the correct way. |
