![]() | Home > Technical (L405) > Should my gear paddles work in 'D' ? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1324 ![]() ![]() |
Yes it should check your owners manual its all described there.
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 ![]() ![]() ![]() |
There’s an option in the menu to have them only available in S. With car running in P enter the menu via steering wheel button and navigate to the appropriate menus. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
As above |
Minghis Member Since: 03 Jan 2022 Location: South West Posts: 8 ![]() ![]() |
OK, thank you for your replies, I have found the setting in the menu for the paddle change and selected both D & S which now works for me.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I have to say I have not felt tge need to use the paddles on my 5.0.
To recall memory function you should only have to press the number button to which position you want. By pressing the M button you are overwriting the position stored.
Yes, I do that but the issue is not the process or sequence, it's the M button not doing anything. So, if I want to set position 2, 3 or 4 for someone other than me (through a long process I have set 1 for me) they adjust the seat, then press M then a number other than 1.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
Even though we sell the flappy paddle kits for the L322, I rarely use them on the L405. They make a huge difference to driving the 5-speed and 6-speed cars. Less so on the 8-speed cars as it is always in the right gear. Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
