![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 - Stage 1/Economy/Custom Re-map / TDI Tuning CRTD4 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
This is one thing I'm thinking. Maybe a full re-map isn't what I want and actually I just want some custom mapping on the transmission ti make it quicker at engaging and shifting. That said, you'd want to change throttle response and turbo timing to achieve the full benefits. 2015 Range Rover Autobiography 4.4 SDV8 |
As I said - speak to BAS (Bell Auto Services). 2012 TDV8 Vogue (L322) |
but I'm still a bit mystified why someone would think the shifting or throttle response is slow on a TDV8 4.4. I'd say the shifting is not optimal vs revs and torque and probably programmed for emissions and economy over drivability and hence why I'm increasingly using the paddles but when I do the shifts are near instant and way better that on the ZF6 speed on my old Audi with paddles which I never used. 2012 TDV8 Vogue (L322) |
This:
Have you tried sport mode? 2012 TDV8 Vogue (L322) |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Im surprised you had issues with it. What car was it? Did Andrew sort you out with the return? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’m following this thread with interest…
Saab 9-3 TTiD. Surging power delivery and unstable speed control. Andrew tried to fix a few things but I think I ended up selling it on ebay. The map wasn't that much more expensive. 2012 TDV8 Vogue (L322) |
Oh very surprising as wasn’t that a commo. Vauxhall and Isuzu engine? I think I’ve even seen it in some boats.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2726 ![]() ![]() |
Ensure that the ecm is at the latest level. My April 12 build wasn't and the driveability improvements after updating to the latest level were significant, which included keeping the torque converter locked at lower engine revs on light throttle. However IMO there is room for improvement in torque converter and gear selection management from standstill when using more than very light throttle, particularly noticeable taking off uphill or when towing. |
Avon Tuning, Celtic and Rhino, all respected companies perform ZF 8HP tuning.
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
You know Andrew, or 'Abyss' as he used to go by? Had the old DTUK Green on my 1.9 CDTI Astra H and it went like ![]() 2000 4.0 P38 HSE - 'Green Goblin' - Gone. Audi..Mini..BMW.. |
Cheers Bl4ckd0g, I’ll have a google and a nosey at them. ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Good point GraemeS. I’ve read about that before… possibly from you! I do intend to flash the engine and gearbox to the latest versions once I’ve cleaned the gunk. I’d like to see that improvement first, before flashing. At that point I should be “as intended” and can decide if that’s enough for me. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
