![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 - Stage 1/Economy/Custom Re-map / TDI Tuning CRTD4 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
How did you do the flash? Did you get someone to do it or did you pay GAP for each of them and use the IID tool or? 2015 Range Rover Autobiography 4.4 SDV8 |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I had read online about a few companies who perform these 8hp tuning services, but none specified the Range Rover. Mostly BMW, and some Audi. I know the gearbox is the same so my assumption was that if you can do one you can do them all… but apparently the Ecus are different and some don’t allow access to the data!?!? At least that is what I was told by one company. I wait with baited breath on what you get from Celtic tuning… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
The difference in the gearbox is the ECU mapping and torque limiting, the high/low range gears and the mounting points (and I think also fitment, as this will vary based on crank). The interior mechanicals however are exactly the same. If you have taken one apart before (as I have) - they're identical. The variant in the RR is the ZF 8HP70. I think it's referred to by ZF with an X also, as I think this means the 4x4 transmissions with high/low range.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
My own opinion after extensive research is these engines are robust but quite finely balanced. I've had the engine out this year, and I've worked on and tuned sportscars including heritage motor sports.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2701 ![]() ![]() |
GAP's IIDtool couldn't re-flash the ecm at the time (and AFAIK still can't) so it was done by a LR dealer. The dealer only agreed to do the update because I referenced the known issue of fluctuating speed at 100/110 kph when using CC, charging for the job at their normal hourly rate. It solved that issue and generally is a lot nicer to drive, especially when the map sensor is freshly cleaned. |
Avon Tuning have clarified:
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7933 ![]() ![]() ![]() |
Least you know now. Though I think the 70 in the gearbox type refers to 700NM rating. I think it’s a different number in some other applications, like 80 or 90. Not sure what internal changes are done to achieve this.
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
garyRR, did you try the TDI-Tuning Box? Seems interesting, but can't find any info about what these 7 modes do... Also my thinking is, that it can't be comparable with proper ECU remap, all it can do is simply fooling the ecu with inputs. |
Mine had a Viezu economy with EGR delete remap which has about the same power and torque increase specs as the Celtic Tuning economy remap. I'm very pleased with the responsiveness for moving off the mark especially joining traffic from a stand-still yet without any compromise to ambling along at low revs in off-road situations. The torque converter is more inclined to stay locked in light throttle situations where previously it would have unlocked, presumably due to the engine now capable of providing enough power to stay above the threshold but also locks sooner after it has unlocked. I've noticed a slightly longer time for the temperature gauge to get to normal. WOT from about 70 kph for a few seconds probably produced a little more black smoke than previously but got the job done very promptly. |
Which is pretty much what most run-of-the-mill remaps do - they have an offset programmed in to lower the fuel pressure sensor value and the IAT which causes the 'proper' maps to over-fuel and adjust the pre/post injection strategy. I know an ex-employee of the LR development & test department and he's pretty scathing about remaps, EGR delete etc. etc. - but he would be, wouldn't he?. Coincidentally, I had to look at a boy-racers car today with an active rear differential fault, aside from having missed an oil change in it by nearly a year, a Milltech exhaust that was far too close to the rear diff (which probably contributed to it's overheating, the protective coating inside shedding and contaminating the oil) it was clearly remapped - just looking at the live values for boost pressure, IAT and a couple of other inputs at key on engine off and idle confirmed it enough to ask 'and how do you want to pay, sir?' despite having extended warranty - oh, and the GPF was blatantly removed and the car had a three month old MoT on it, that's gong to be interesting ![]() |
I decided not to proceed with a box or remap.
There's a couple of things that can affect drive away response, the first one (on the L494) is how hard you press the brake whilst at a stop, too hard and the transmission won't be primed for action. Secondly, and one I've used for years, is left-foot braking - rather than having the delay going from stop to go, you can get the revs moving up as you're coming off the brake, it also gives a smoother drive as opposed to stabbing at the throttle once you've released the brake, it takes a bit of practice, but once you get the hang of it, it's a much more responsive way to control the vehicle. |
