Home > Maintenance & Mods (L322) > 4.4 TDV8 coolant leak.
kevinp
I've been trying to track down a coolant leak for about a year now and finally found it. I cobbled together an old pressure tester and modified an expansion tank cap and pumped a bit of pressure in. I can see water dripping from the engine side of the top hose. I'm getting a new expansion tank and some coolant and hope I've finally cracked it.
Post #574356 27th Nov 2020 10:10pm
mjdronfield
That’s good then. I thought you were gonna say that little connection near the top of the radiator that always breaks, but then you would have seen that easily.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #574361 27th Nov 2020 10:22pm
kevinp
Gonna try my best to not break it mate. I've got a spare top hose up to that joint from the engine side so much care will be the order of the day.
Post #574369 28th Nov 2020 12:21am
DrRob
Re: 4.4 TDV8 coolant leak.
Did a new top hose fix that coolant loss Kev? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620537 19th Jan 2022 9:09am
kevinp
Yes mate. I put a new expansion tank on as well, because it was filthy inside, and I can now see a nice steady level.
Post #620540 19th Jan 2022 9:25am
DrRob
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620541 19th Jan 2022 9:47am
