Home > General > 04 TD6 vs 04X5 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
BMW said the TD6 was always meant to have the lower powered version of the M57 engine…. But then they would say that, as they had sold Land Rover by the time the L322 launched.
17th Jan 2022 11:34pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 443 |
Did the remap also effect mpg? |
18th Jan 2022 12:22pm |
To be fair, I didn’t really notice. Obviously if you are using the extra power more, compared to before, you’ll use more fuel, but I found the low/mid range torque was much better, so in normal driving, I used less throttle to get the same result… car was smoother too.
18th Jan 2022 12:40pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
The RR TD6 was under powered because the gearbox in under spec for the weight of the car
18th Jan 2022 2:08pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2688 |
The X5 will be faster - until you go off road. 2012 TDV8 Vogue (L322) |
18th Jan 2022 3:54pm |
Yes, in one of my Range Rover development books, BMW sent over an X5 with a boffin… to Eastnor Castle. They took said boffin round in, I imagine, a P38 or a Disco, and said “it needs to do that”. The guy didn’t bother getting the X5 off the trailer….
18th Jan 2022 4:44pm |
If you don't need any off road ability then an X5 is a reasonable choice. Mind you if you don't need any off road ability you may as well just buy a 5 series (estate if you need the space). 2012 TDV8 Vogue (L322) |
18th Jan 2022 5:07pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
I think it’s mostly down to weight, the X5 is, I think, has a shorter wheelbase and definitely much lighter than the TD6.
19th Jan 2022 8:46am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
I met some of the instructors who worked on the X5 launch. They were far from complimentary about its off road abilities. What do I put here then? |
19th Jan 2022 10:21am |
Wasn't the L322 a BMW design project ?
19th Jan 2022 6:32pm |
Yes, BMW reportedly spent £2 billion designing and developing it. Sold to Ford before launch.
19th Jan 2022 7:51pm |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Always thought what if only…
23rd Jan 2022 3:20pm |
