![]() | Home > Technical (L322) > L322 2011 4.4 V8 front heater not working |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Sounds like your heater blower has packed in if it doesn’t work on any of the speed settings, I’ve done a post on how I changed mine but before I’d remove the pollen filter housing, turn car on and start the fans if there working you will see them spinning if not spinning it’s time to change unfortunately 2012 Range Rover Westminster 4.4 TDV8
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
Cheers for the reply mate. Appreciate it.
Open bonnet the pollen filter is at the back there are two 13mm bolts holding it in place it’s a big bit of kit when it comes out 2012 Range Rover Westminster 4.4 TDV8
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
When I was putting my MY11 in for a blower motor replacement, there were other L322s also getting new blower motors.
How would I know which one it is without doing one, it not being that and then the other one? I don't think you're going to be able to tell me lol |
My blower motor was on the way out for a while. It blew a few FSRs and the HVAC control module before it finally gave up.
I've just thought and it might be a coincidence, there's been a squeak coming from one of the belts under the bonnet. Could this have anything to do with it?
If the squeak / chirping is still happening after your blower motor is stopped, then it could be belt and / or idler pullies
Update - I've took out the pollen filter (see pictures) but I can't see any motors. Am I missing something? I've had the blowers off and on full, without the pollen filter. Still nothing. |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi stuartj9,
Have a look at this post from me… and the messages from furnatureman who has tackled replacing the blower. I’ll be updating my progress here…
Cheers mate. I think the air/blow is coming from the fan by the radiator, so nothing to do with the heating.
